Smelly washing machine
Are there any filters to clean
  • Cath Jan 19, 2013
    There is a filter on the left hand side of the machine when facing the front of machine it takes a bit of removing but was very yucky and I also used vinegar and carb soda on hot wash to flush machine thanks for your help
There are no filters to be cleaned on a washing machine. One way to help the odor from a washing machine is to do one large load with nothing in it, and use 2 cups of ammonia.
Let me know if this helps
Posted on Jan 17, 2013
SOURCE: Where is the filter on a WMA32
the rear of the machine has a metal plate with 4 screws the overflow pipe goes in there take this off get some one to tilt the machine forward the overflow pipe goes to the pump then another pipe goes the the filter large clip removes the filter inside is a cradle and a ball anti return for water clean it all and job done .hope this helps all regards george
Posted on Oct 05, 2008
SOURCE: i cant get the filter out of my washing machine help please
Sometimes a bigger object might block the filter knob, and make it impossible to screw out. Then the only way is to remove the end of the sump hose attached to the filter and remove the stuck object.
(In my filter this object was an Umbraco key) :-)
Posted on Feb 09, 2009
barkencoa
  • 3463 Answers
SOURCE: loads of slimey grey water in filter drawer and horrible smells
First of all, you need to confirm if the leak is from the filter or the pump.
You can replace the filter seperately to the pump.
If you replace the filter, and it still leaks, then you are going to have replace the pump.
I would suggest that that you check and clean if needed the outlet pipe where the water enters the outside waste pipe.
Make sure that you do a boil wash periodically, to ensure that the drum and other internal parts are clean.
Clean the door seal and dry after each wash, it helps to leave the door slightly open
Please leave any comments that may have as regards to my suggestions.
Thankyou.
Posted on Nov 25, 2009
apart4u
  • 213 Answers
SOURCE: Stinky grey goo in my Hotpoint WMA20 washing machine
you can only change the seal as this is a common fault with low tep washing Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Smelly front loader washing machine.
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
Testimonial: "I haven't tried this yet but I'm about to. But I must say, I have never seen powedered dishwashing detergent. Do I get it from the supermarket or .."
Clean awm5104 washer filter
There can be many issues but you need to remove and clean all the filters and the drum, the drain.
check this link for tips: Smelly drum
Nov 20, 2013 | Whirlpool AWM5104/1 Front Load Washer
Smelly Washing Machine
There is a product called washer magik and is designed specifically for the problem of smell. The rubber bellows, or gasket, is notorious for causing that to happen.
Apr 26, 2012 | Hotpoint WMA54 Front Load Washer
I WANT TO CLEAN OUT THE FILTERS BUT CAN'T FIND THEM. tHE WASHING MACHINE IS 3 YEARS OLD AND IS WORKING BUT IS A BIT SMELLY AND CLOTHES ARE NOT AS CLEAN. I USE REAL NAPPIES AND USE THE MACHINE DAILY SO IT'S...
Remove lowwer rrear panel. locate and remove the large black hose fastened to bottom of drum, there should be a plastic filter inside the hose, if not, then filter is located at bottom front right of washer behind cover.
Sep 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Washer smells moldy even though the door is left open between batches Could the filter need cleaning?
no filter there to clean need to visit smelly washer.com and run that stuff thru a cycle
Jul 28, 2010 | Kenmore 45081 Front Load Washer / Dryer
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Hotpoint First Edition FEW10 filter/smell
Filter is located in the big hose from the drum to the pump, called the sump hose
Access is via a removable panel at the rear of the washer. remove hose and clean filter.
Aug 07, 2008 | Hotpoint First Edition FEW10P Front Load...
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
