Question about Garland Ovens
We have a commercial garland oven that need a thermostat
It has six burners,two ovens,a griddle and broiler. all work but we can't find anyone tell me the right thermostat to use to fix it
3 Suggested Answers
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
VtToolMan
  • 704 Answers
SOURCE: MY oven is not working. The burners and broiler do
If you can see the oven ignitor glowing bright orange when you turn theoven control on to say 350 degrees. (look down at the back bottom of the oven compartment near the back wall of the oven).
If there is no glow, then you have a faulty ignitor. If you can see the ignitor glowing and the owen doesn't light, then it is the thermocouple that controls the flow of gas from gas supply valve that is bad.
You'll need to replace the defective part(s) to get the oven working properly. You can find the parts on the link included along with some pricing at searspartsdirect.com but you can buy parts anywhere you wish.
You'll have to pick which oven version you have as you need one more letter at the end of your model number (it's usually a small printed letter after the larger model number on the label eg: A, B, or C.) so you can look at the parts list to select the correct parts for your oven.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=gKpqVBTSaohlK3kbhZ+WFQ**.shcapp3105?modelNumber=+FGB24S5A+&pop=flush
Hope this helps you get cooking again! Best Regards!
Posted on Jul 31, 2009
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
Gas burners on top of stove work but broiler & oven do not heat up.
Hello'
Does your model have an electronic ignition? If so open broiler drawer ,turn on oven and look for bright orange glow. May take a few seconds.If it glows but no or poor flame .replace oven igniter.If no glow at all , check for voltage at igniter when switched on to see if it may be oven thermostat . Get a tech to test if not sure.All easy to fix.
Hope this helps
Aug 16, 2011 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Kenmore gas stove - Top burners work but the oven doesn't
Hello Melanie!
Does the oven not heat? Are you able to program the oven at all? or is the display or read out blank?
Do you see any error codes? What youre experiencing may be control board related. If so, Fixyourboard.com can help. Feel free to respond to these questions here -- info@fixyourboard.com
Best,
Megan
Jun 05, 2017 | Kenmore 30464 / 30465 / 30469 Gas Single...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Ovens Logo
19 people viewed this question
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
