Question about Reddy Heating & Cooling
Heater won't ignite
Heater was operating and shut down.it won't reignite
Moving mine while it was running fouled the spark plug. You can remove the top of the Reddy Heater and access the plug. In my case took less than 10 minutes and it's up and running again. I removed the top and replaced the spark plug. No problems
Posted on Jan 12, 2010
We have had major blackouts does my bosch highflow 21e need to be reignited or automatic....how long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
The hot water temperature is not constant with the burner shutting off
You can get a sound like that when there is too much sediment in the bottom of the tank. Turn it off drain and flush it until the water runs clean.
Aug 21, 2014 | Water Heaters
How to reignite my heating vent after unplugging it for a day it won't work
is it electric? is there a thermostat? is therere a fan in it? is the filter clean? I used to be an ac / heating contractor. I need more info.
Feb 22, 2013 | Heating & Cooling
Flame stops suddenly after running for a while. Yes, there is fuel.
Check that there are no leaks, to do a leakage test see patio guide to problem solving. If OK then check the thermocouple, when worn out they will cause the pilot to switch off.
Nov 18, 2011 | Endless Summer 233010 Natural Gas...
Heater ignites and runs about 15 seconds and shuts off, then it reignites and does the same over again, have replace the igniter and checked all the saftey switches found them to be okay, did by pass the...
After a startup sequence determines that it is safe to turn on the gas and ignitor. Unfortunately it didn't detect ignition so it shut the system down. It could be the ignition sensor, wires or the controller. I suggest contacting the Hayward technical support and they may be able to walk you through the diagnostics. I hope this helps. PS. If you get it going don't forget to fix the bypassed air valve you mentioned.
Aug 04, 2011 | Hayward H Series Induced Draft Abg 100,000...
My backett hell R7184B furnace is will not reignite when I hold the reset button down. I had run out of oil yesterday and believe I've bled all the air out of the lines. I held the reset button down for 30...
You may still have air in the line. You will need to hold down the button again with a hose on the bleeder screw and open it. Do this until no bubbles come out of hose. Just keep holding the reset down for up to a minute.
Feb 21, 2010 | Honeywell Heating & Cooling
Goodman gmt or gmth not igniting burner. We have
First pull wires off the pressure switch and put a jumper wire in, if it lights bad switch. If it doesn't light, bad ignitor.
Jan 04, 2010 | Goodman GMS90703BXA Heater
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Heating & Cooling Logo
149 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
