Question about Video Game Consoles & Games
Manual for Hanna C203 multiparameter meter - Video Game Consoles & Games
Trouble shootfuel guage94 jeep cherokee
gauge stuck high or low or"??????????????
how to ?
with no tools or with ?
got meter? or nothing.?
is tank full now, empty?
knowing that we can check the sender.
using an OHM meter, dmm set to resistance
unplug sender and check its ohms to ground.
infinity reading is bad sender
btw at 63ohms the sensor is at, cause the low fuel lamp to glow.
page 8e-6 in the factory manuals shows doing all this.
its in every jeep book in print. XJ jeep.
8e-23 shows.
empty tank is 105 ohms
1/2 full is 33 ohms
and full is 5 ohms.
first is fuse good to cluster, do all other guages work?
then unplug C203, below near tank
see that wire,DB, (dark-blue)
measure it to with ohm meter, must read 5 to 105 ohms
if not and is why too too high .
unplug C307, and measure black to VT, (violet?)
100 to 5 homes if ok now, the ground wire there is rusty.
if not ok, the sensor is toasted.
if all this check ok.
then at c203, DB wire ground that wire,
and gauge must go to fULL key on,
if not . the DB wire is bad, or custer guage, bad,
if this test fails we do this same grounding test
at the actual gauge. if fails, gauge is bad.
Nov 02, 2016 | 1994 Jeep Cherokee
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Hanna hanna clue famous people starts with r
Hello i dont know any hanna hannas but if your playing clue pics on level 19 the answer is Rihanna :)
Aug 12, 2013 | Office Equipment & Supplies
Do we need to calibrate the pH meter every time we measure an acidic solution or alkaline solution?
No I have a hanna phep for my koy pond I never calibrate it just clean it in fresh water every use shake it in water
Feb 28, 2011 | Hanna pHep pH Meter with Solutions
Hanna montana mix it doesn't charge or turn on. i
Try resetting, you will need a small pin, but that worked to turn ours back on, except now we have other issues.
Jan 11, 2010 | Disney Hannah Montana MP3 Player
Video Game Consoles & Games Logo
50 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
