Question about DeLonghi Pinguino PAC-02 Air Conditioner
I have a electrolux split system about 4 years old and its not cooling alot
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
Split air conditioning sytem- not cooling very well (maybe gas problem). previously had icicles coming out of fan. How much should this cost to repair. 5 year old system.
On average a service call should be around $75 to diagnose what's wrong. If it is low on freon there must be a leak somewhere and will have to be found and repaired before more freon is added. Cost would depend on the amount of time it takes to find the leak and if it can be repaired.
Mar 21, 2011 | Electrolux E23CS75SS Air Conditioner
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
Useing/loosing coolant at high rate. Steam coming from under engine cover, what could the problem be ?
It sounds like you have a problem with one of the rubber hoses in the cooling system leaking.
The heater hoses and those little bypass hoses in the cooling system tend to go hard and split if they are close to 10 years old, allowing coolant loss. Check all the hoses in the engine bay especially where they attach to the pipes around the engine for loose clamps or splits. Replace any hoses and clamps that are have gone hard, split, leaking or not sealing ptoperly.Those spring type hose clamps tend to be less effective in clamping as the hoses become hard. Worm drive ones are the best to use.
Oct 30, 2010 | 2001 Jaguar XJ8
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
DeLonghi Pinguino PAC-02 Air Conditioner Logo
19 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
