Question about Spectra Ford F-150 96 95 94 93 92 F-250 F-350 F Super Duty Parts Car Auto 1996 1995 1994
I replaced a fuel pump on my 1995 f150 ext cab 5.0 and now it wont start, it has spark, is getting fuel in the rail,,its turning over, i replaced the plugs and distribultor cap and button and i put a new fuel filter on it but just wont start????
    Genius:
  • 1,003 Answers
Try pouring gas directly in the carburator and see if it starts.
if so maybe the fuel pump u installed is defective go back to point A
Posted on Jan 22, 2013
1998 ford f150 6cyl fuel pump not working. Replaced it and fuel filter. Pump working fine, still wont start. Where should i go from here?
You say the pump is not working but the pump is working fine ??
What is the fuel pressure at the injector rail ?
Jan 24, 2013 | 1998 Ford F150 Regular Cab
I REPLACED MY FUEL PUMP ON MY 1999 CHEVY SILVERADO EXT CAB P/U TRUCK AND IT CRANKS BUT IT WILL NOT START...ANY SUGGESTIONS?
did you check for fuel pressure at the fuel rail?
listen for the fuel pump when you turn the key on
did you change the wire harness when you changed the pump?
Sep 25, 2011 | Cars & Trucks
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
1995 ford f150 - truck ran fine.turned on turn signal and started around turn and truck shut off and will not start.it has no fuel pressure in fuel rail and no diagrams for fuel pump relay's...
You can get a 1996 manual at the link below. That may be close enough. It shows 5 relays in the box under the hood. Relay 2 is for the fuel pump. Your wiring diagrams are at the second link below, and the particular diagram for the relay is at the third link.
http://www.fleet.ford.com/partsandservice/owner-manuals
http://www.bbbind.com/free_tsb.html
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=2020
Aug 07, 2017 | 1995 Ford F150 Styleside Regular Cab
2003 4.6 f150 wont start replaced fuel pump, filter engine cranks computer reads all systems fine
When you turn on the key to Run, do you hear anything? There is an Inertia cutoff switch which kills the power to the fuel pump. This switch is usually behind the front kick panels and has a reset button that you push. It is a safety switch and can sometimes trip if a doorslam or impact is felt by the sensor.
There can be a Fuel pump relay in the black powerboxes, but there is no Code, so it should be okay. If you have a gauge to measure fuel pump pressure, check to see if the fuel pump is working by measuring pressure at the fuel rail.
Nov 06, 2010 | 2003 Ford F150 Regular Cab
Replaced fuel pump it has gas and spark but wont
i would ck timing & replace spark plugs any way,,still should ck fuel pressure,,at fuel rail,,,
Feb 20, 2010 | 1995 Plymouth Grand Voyager
I replaced the fuel pump on a 1995 taurus and it wont start
have you checked the fuel rail for fuel. if its getting fuel andstill wont start check the coil pack. its hard to say with out seeing it but if have fuel or spark its gotta start so check coil pack for spark if you have done fuel. best of luck
Nov 19, 2009 | 1995 Ford Taurus
Wont start
Spark when cranking? Possible bad sensor
Apr 24, 2009 | 1996 Ford F150 Regular Cab
When I switch from my front fuel tank to my rear tank gas stops
There is no selector valve on a 1995 ford f150 300 engine. The selector switch on the dash sends power to the pump in the selected tank. The pump then sends fuel to the engine. If engine won't run on the selected switch, the pump in that tank needs replaced.
Mar 28, 2009 | 1995 Ford F150 Styleside Regular Cab
1995 ford f150 fuel pump
Your truck is fuel injected. On the fuel delivery rail in the engine compartment there is a cap you can take off to check for fuel pressure. Hook a mechanical gage to it and check to make sure the fuel pump is working. Also if you have a dash switch to change over to the different tanks check it. Often these switches become bad and the fuel will not flow. The switches are about $ 40.00 dollars. To replace the fuel pumps you must drop the fuel tanks and remove each fuel pump from the tank. The cost for the pumps alone will be about $300.00 to $ 500.00 depending on who you purchase them from. The universals are cheaper, but the Ford pumps are an exact match and you can change them with out any problems.
Feb 08, 2009 | 1995 Ford F150 Styleside Regular Cab
Spectra Ford F-150 96 95 94 93 92 F-250 F-350 F Super Duty Parts Car Auto 1996 1995 1994 Logo
82 people viewed this question
Top Spectra Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Timllfixit
ray gallant
Are you a Spectra Car Audio and Video Expert? Answer questions, earn points and help others
