Question about Toto Neorest 600 1pc. Toilet MS99OCGR-01
Bidet wand malfunction
The wand extends and adjusts but no spray. I recently cleaned the inlet screen (filter). It was clogged with black greasy gummy stuff. After cleaning, the wand seems to work better, but still no spray. I'm thinking How to take it apart in order to clean the wand cylinder and nozzles from the inside.
2 Suggested Answers
muralme
  • 20 Answers
SOURCE: Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Posted on Jul 12, 2009
No suction from dyson dc24
Clean or replace filters if needed. Check for suction at wand, if not good could be a clog somewhere or clogged filters, or a leak in the suction somewhere. If good at hose but not at floor it could be a clog or malfunction in changeover valve area. Make sure brush roll is spinning good and brush roll not worn out or frayed.
Mar 14, 2017 | Dyson Vacuums
Centralux
Low suction is either a clogged pipeline (very rare), a broken or open inlet valve in the system, a clogged hose or wand system, a clogged washable filter, the small screen behind the filter when removed needs cleaned, or the motor itself. Would need more detailed info. to pinpoint but hope it helped!
May 31, 2014 | Electrolux Vacuums
Wand will not launch when seat is activated
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism . Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Home
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wand doesn't fully extend anymore
Fully extend, or extend at all?
For the wand to properly travel, it needs to be regularly cleaned. From the User Manual:
<< When the nozzle does not come out: Check to see if the skin sensor is touching skin (hint: unit will beep when skin is recognized).
Aug 16, 2013 | AMDM Intelliseat - The Ultimate Bidet...
You may have another malfunction here. Get your manual and see what it says under troubleshooting.
Jan 17, 2013 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Waterblaster has no pressure
It would help to identify the Brand of product. Check your wand stem. Most wands have a filter inside to keep the spray nozzle from clogging. Some Brands have filters just inside the coupler to the water source. Most of these screen filters just pop out for cleaning.
Jun 29, 2012 | Cars & Trucks
Need to clean filter
You will be able to take the spray covers and flat pipe across the back.
Remove the flat pipe by twisting the pipe and cover counter clockwise.
Remove the spray wand by unscrewing the thumb screw in the center counter clockwise. Remove it. Take pictures with your phone along the way.
At the base are about 6 screws you will have to remove with # 7-10 torx screw drivers you can get at Sears.
Carefully remove the screens and the screws. You will see the screen which you will have to spray with a hose to clean out that probably has build up.
Last, the motor below the screen needs to be unscrewed and you need to open this area to see if the screen area is not clogged. It probably is and needs to be cleaned like 1 per year. This is tricky to remove this cover. You may need to carefully use a hooked screwdriver to remove the lid.
e
Nov 22, 2011 | Frigidaire Dishwashers
Really dirty and greasy filter and screen
Remove the filter or if it's part of the cover forget about removing it, spray liberally with "Easy Off" oven cleaner and place in a black plastic bag in the sun, if there is no sun put it the warmest place you can find, after 24 hours spray the filter with the highest pressure water you gan get this should do the trick.
Feb 27, 2009 | GE 168997 Deep Fryer
Toto Neorest 600 1pc. Toilet  MS99OCGR-01 Logo
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
