Question about Cobra Dvc910 Red-5mp Dvc910 Video Cam - Kit
Does anyone have a software for a cobra camcorder DVC910?
Unable to install the driver for this device and it's giving me an error code 43.
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
Windows has stopped this device because it has reported problems. (Code 43)
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Oct 05, 2013 | Nokia 6230i USB
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I have windows 7 and wants to install hp psc 1310 but facing code 43
you probably have the wrong driver installed. Most likely you have upgraded to a 64 bit system, and the driver is 32 bit. Find out which system you're running (right click 'computer' and click 'properties').Disconnect the printer and Uninstall the software, then go to hp website and download the proper software and install here:
May 13, 2012 | HP PSC 1315 All-In-One InkJet Printer
Device not detected
Whenever windows reports a code 43 error msg is because the device driver is corrupted or is reporting a failure, re-install the driver if error persist contact the manufacter of the device showing the error. Best regards Luis!
Feb 17, 2012 | Gigabyte GE-S800A-D1 ODIN GT 800W POWER...
YES IT COMES WITH A CABLE TO CONNECT IN THE USB PORT.I TRIED ANOTHER CABLE STILL THE SAME,THIS PART WORKS AS BLUETOOTH AND WIFI.THE BLUETOOTH IS WORKING GREAT BUT THE WIFI CANT BE RECOGNIZED BY THE WINDOW7...
Error code 43 means it's a driver issue. You need the original drivers of your bluetooth device If you know what is the brand and model of your bluetooth device then you can just download it. =)
May 22, 2011 | Computers & Internet
Computer see error code 43
Update the drivers for the device. It's also very possible that installing the latest drivers for the device could correct the Code 43 error.
Install the latest Windows service pack.
Update BIOS.
Replace the data cable that connects the device to the computer,
Reference the hardware device's manual
for more help regading this issuer or other issue visit https://cbrtechsolutions.net
Feb 17, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Vista unable to find drivers
Have you tried installing the supplied software the Setup/Install program in Administrator Mode, with Compatibility Mode set for XP? Install the software like this and AFTER you install it THEN plug in the camera, if it asks for drivers.. let it search the computer point or it to the CD.. Hope this was of some help.
Aug 02, 2007 | JVC Everio GZ-MG130 Camcorder
Cobra Dvc910 Red-5mp Dvc910 Video Cam - Kit Logo
29 people viewed this question
Top Cobra Video Cameras Experts
Tony Parsons
Tony Parsons
Are you a Cobra Video Camera Expert? Answer questions, earn points and help others
