Question about Samsung LNT4669 TV
Lnt-4665 flickering and part of bottom screen rolling to top
The TV is flickering with lines on the screen and the bottom of the picture rolls to the top. This only happens when certain things are in the screen with lines or menus. Happens on all sources and can reproduce.
  • erichouse8 Jan 18, 2013
    I have the TV connected to verizon fios but it happenswhen the DVD player is connected and my hone theater pc. I will try the hard reset but i have noticed that the fkickering and screen roll will happen even when the tv first turns on.
  • 308 Answers
SOURCE: Flickering picture and color lines
You didn't mention what equipment you have hooked into the set, Cable Box, Satellite, DVD., etc. So I would try using a different component or different cables to make sure it is not an intermittent connection either in some of the cables or an external signal source. Otherwise a warranty call may be justified.
Posted on Mar 12, 2007
  • 267 Answers
SOURCE: Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Posted on Jun 26, 2009
  • 5 Answers
SOURCE: 4665 samsung has sound but no picture
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent.
Posted on Jul 28, 2009
budmrtn
  • 11361 Answers
SOURCE: SamSung TV Model LN-T4066F Model Code
Look for bad caps in the power supply first.
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN-T4066F/
Posted on Jun 03, 2011
gopakumarg43
  • 75599 Answers
SOURCE: Samsung LCD TV LA40S81.... Turn on
Hello
It is due to the power regulator section of your TV. If DC voltage come to T'con board and other circuit board won't have enogh regulated and smoothed current this type of fault will occur. Open your Tv and check for any bulged capacitors on the mains power regulator board. If there, repalce it with same type and capacity. I hereby attaches a picture, of an other set's power supply board with bulged capacitors to give you an idea about how a damaged and bulged capacitor will look like. Check this, If you want anymore assistance from me, feel free to get me by Fixya.
gopakumarg43_41.jpg Note the top of the red arrow marked capacitors. They are damaged. A ggod one will look like one you can see on the top right with flat top surface.
Posted on Sep 04, 2011
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
Jul 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
The horizontal on the screen has moved i have a 2
i have same problem it happens with my hdmi and component port.
did you ever find out what the problem was?
Apr 07, 2009 | Sharp Televison & Video
Red & Green lines rolling from the bottom to the top
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Dec 27, 2008 | Televison & Video
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
My tv rolls from bottom to the top
It's a bad cable connection. Move the cable wire and see if there is a difference. The bad connection can also be at the cable box outside.
Jun 29, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Samsung LNT4669 TV Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
