Question about Onkyo Quartz Synthesized Tuner Amplifier Ri Model Tx-840 Remote Control
Speaker buttons don't function correctly
This is a pretty old receiver, but I just started having this problem (or at least just noticed it): The only time I get sound is when Speaker B is "On" and Speaker A is off. When I turn Speaker A "on" and Speaker B "off". When I hit both speaker buttons to "On" position, no sound comes out. So I am only getting sound out of speaker B. I want both sides of the stereo!
    Top Expert:
  • Onkyo Master
  • 43,164 Answers
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Posted on Jan 17, 2013
  • 5 Answers
SOURCE: Settings
As mentioned, I have got to the bottom of this without Onkyo's help. I replaced the offending component, which is a 5.5V 0.1F backup capacitor. This is mounted on the front PCB, just below the right hand side of the display. It is a right pain to get to. Here briefly is what to do:
1: Unplug (really important!), remove top cover.
2: Undo three screws underneath front panel edge, pull off volume and tone knobs, and gently pull off metal front panel from the bottom, which is held with sticky tape inside.
3: Undo five screws from plastic front panel and free it. You will now have limited access to the front panel PCB and audio processor PCB.
4: Cut a few black cable ties as required to gain better access to front PCBs, and unplug ribbon cable from right hand side. It may be helpful to undo the nut and so release the volume control encoder.
5: Still struggling with poor access, release the standoffs from the audio processor PCB and unplug its ribbon cable. You have to remove the audio processor PCB in order to get to the screws under it. You may want to remove the PCB for holding the mains switch.
6: Now with some kind of access to the whole of the front panel PCB, undo 10,000 screws which secure it to the black plastic front panel.
7: Now with limited access to the front side of the front panel PCB, locate the capacitor, towards the right hand side of the display, just beneath it. Note the polarity; the negative terminal goes to the left/top pcb land, positive to the bottom/right. Desolder and replace this component. HINT: Make life easier for next time and mount the new part on the REAR of the PCB, so now negative will be down. Care with polarity!
8: Reassemble carefully. Make sure that the volume control encoder metal clasps are tight as they come apart easily. Fit new cable ties in original locations (important to prevent hum pickup).
The parts you will require then are about 6 nylon cable ties, and a 0.1F 5.5V capacitor. I had to make do with a 0.047F part because it was all I had to hand and I didn't want the machine in bits while I ordered one. Many of these components today are radial PCB mounting, which are not an ideal fit but could be used at a push. If you can get a vertically mounted one, that would be better. The nearest I can readily find is from RS Components item 377-350 (Panasonic EECS0HD104V), and the leads on this could doubtless be re-jigged to fit.
Posted on Mar 09, 2008
SOURCE: Speaker volume settings
I figured out the problem.  After you set the individual channel volume for each speaker you need to push the test button on the remote and this will lock in the settings.  Thanks.
Posted on Oct 25, 2007
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
  • 151 Answers
SOURCE: I have a Onkyo 805
WILL TRY TO GET A SOLUTION FOR YOU IN MORNING CALL ME ON 02870342354 LARRY. I HAVE NOT SEEN THIS ERROR BEFOR AND I SELL ONKYO IN THE SHOP I WORK IN,(LIGHTING,SOUND,AND VISION) IN NORTHERN IRELAND OR EMAIL ME AT LSVNI@YAHOO.CO.UK
RICKY.
Posted on Jun 20, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Onkyo HT-R510
have you tried to reset it to factory defaults yet? If it has a vcr button on the front, then hold the vcr button and press power...it should say reset on the front. Might not help, but worth a try.
Dec 04, 2013 | Onkyo TX-SR601 Receiver
On my Kenwood vr-505 Under the speaker symbol it says clip and there is no sound coming from the speakers
Hello. My name is Dave. Unplug the receiver. Plug it back in. When you first push the power button, you should hear one relay click. Within about 5 seconds, you should hear another click. My guess is, you don't hear the second click. Am I correct?
Dave
Sep 30, 2012 | Audio Players & Recorders
Fixing a Denon 1705. Rear Surrounds damaged by 2ohm speakers.
Chances are that you blew your output transistors with speaker impedance that low
Apr 16, 2017 | Denon Audio Players & Recorders
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
Hi, I have a 3 year old Onkyo TX-SR506 receiver that I bought secondhand. The receiver can get very dusty so I was cleaning the top with a damp cloth while listening to music. Suddenly the music stopped...
I don't think its a harmless coincidence that it happened while you were touching it.
Assuming 'damp' means 'no dripping' I'd discount mositure as the cause. Was there something else you may have touched or caused to move during your actions, like speaker wires? Retrace your steps (with power off) and imagine what may have moved.
Disconnect the speaker wires at the receiver and see if that helps. If so, you just need to start adding speakers until it fails again or not, then isolate the cause if it is related to specific channel(s). If it doesn't come up 'naked' something cooked inside and a hands-on tech needs to get involved.
In the future - turn it off when manilpulating anything on, near or attached to it.
Jul 12, 2011 | Onkyo TX-SR506 Receiver
I was told i might have a fuse blown on my htr-5940,cause the 3 left speakers work for the test but not for actual playing.is that the problem?and where can i find the fuse?
There's no separate fuse for test versus operational speaker function.
Evaluate the source for why the "3 left" speakers (whatever that means) don't work for program material.
Jun 27, 2011 | Yamaha HTR-5940 Receiver
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have the Onkyo 706 with remote RC-717M. My remote just suddenly started to malfunction. The volume up is turning it down and vice versa. The power button to shut the receiver off is doing the function...
Have you tried resetting the remote? According to the manual (page 101), press and hold the RECEIVER button, press the AUDIO button, wait approx 3 sec. until RECEIVER highlights and finally press RECEIVER again. Of course if you've programmed a remote control code for your PVR in the RC-717M, you'll have to do it again.
Oct 18, 2008 | Onkyo Audio Players & Recorders
I am trying to connect my Samsung 56" DLP HDTV to my JVC THD50 home theatre system, all the speakers are hooked up correctly but I can't source from the tv to the speakers correctly, I connected a...
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Apr 03, 2008 | Audio Players & Recorders
Onkyo Quartz Synthesized Tuner Amplifier Ri Model Tx-840 Remote Control Logo
659 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
