Question about NEC Oki Mc160N A4 Colour Multifunction Laser Printer Print/Scan
How can reset error code 310 in oki mc160n
I have this error maachine trouble service call (0310)
310-330 EROR CODE
Whenr. posting error codes, it is best to indicate device, brand, model number. If this is a OKI laser printer, the error code 310 may be indicating a top cover is open. On a canon laser printer, the code 330 may indicate a need to replace or repair a power supply. Codes vary by brand. You might try googling the code plus the brand and possibly the model. "error code 310 brand model"
Nov 10, 2017 | Office Equipment & Supplies
Pls help on how to clear error 0310 on bizhub c20 i have checked all the connection and my print head is ok what next shuld i do to remove this error pls is very urgent thanksa
You didn't say what make of printer it is. Error codes vary from printer make to printer make. Your best bet is to do a Google search for ERROR CODE 0310 NAME (NAME=name of printer).
If It's a Konica Minolta read the link below:
Konica Minolta Bizhub C35 Error Codes
Feb 17, 2016 | Office Equipment & Supplies
How do I get the patch to fix service error 980 on my c331dn
Fix your printer
Here is a link that may help. Please read ALL of the entries to make sure you get the correct information.
Jan 17, 2015 | OKI Office Equipment & Supplies
I have an error code 0310 on konica minolta magicolor 1690mf how do I get it off and get machine working again
The error code 0310 means the SOS signal is not detected within a given period of time after the output of the laser has been started.
To fix this clean the PH (laser) Unit by removing all the toner that gets inside. If that fails, you need to Replace the PH unit (p/n A034 R707 00). If the error returns again, replace the PRCB (p/n A034 H009 07).
Oct 11, 2014 | Konica Minolta bizhub Office Equipment &...
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Maachine stopped before pump out.I have no error message.
Most likely your pump is blocked.
As these run a magneto pump, a small shard of plate or glass jam the pump very easily and your will not hear it running.
You need to take the pump apart and clear it out.
Hope this helps
Jun 01, 2013 | Baumatic 23 in. BDW10 Built-in Dishwasher
CALL SERVICE (0500) what does it mean ? how to solve it ?
The users manual says when you get this error to reboot machine and if the error doesn't go away the problem can only be fixed by an authorized service provider.
Dec 28, 2012 | NEC Oki Mc160N A4 Colour Multifunction...
ERROR code 0310 the waste tone container became full after I emptied it and replaced it the error code 0310 showed up. what is wrong and how do I fix it?
well i have bad news for you....
your print head (laser) is bad.
CAUSE: The SOS signal is not detected within a given period of time after the output of the laser has been started.
SOLUTION: Replace the PH unit (p/n A034 R707 00) and if the error returns, replace the PRCB (p/n A034 H009 07).
Nov 24, 2011 | Konica Minolta magicolor 1690MF All-In-One...
ERROR code 0310
This is a print head or laser failure. it needs to be replaced.
NEC Oki Mc160N A4 Colour Multifunction Laser Printer Print/Scan Logo
289 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
