Question about Honeywell Ademco Lynxr-i Lynxren-6 Security System
What does ac bat mean on my panel?
My panel is showing ac bat and the alarm is not doing anything
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
AC is your main power it goes to a transformer that gets pluged in
Bat is your battery power 2 wires going down to your battery
Posted on Dec 18, 2014
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
The system randomly beeps
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
May 28, 2017 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
1995 2.4 Vauxhall Frontera, fitted alarm immobiliser keeps going off and will not reset. Engine does start eventually, but cuts out when alarm goes off again. Help
check ya battery thats normally the cause
good bat 12.4v bad bat anything below 11.8v
With the engine running
good 13.8-14.8v bad anything below 13.0v
if below 13.0v when running the alternator is broken
Hope i help
bakerboy11@hotmail.com
Automobile
May 17, 2010 | 1995 Isuzu Rodeo
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
Cannot start engine after alarm sounded.
disconect the battery for about 15 minutes and turn the head lights on after bat is disconected and then turn head lights off reconect bat and this should reset your alarm system.
Apr 21, 2009 | 2002 Toyota Tacoma
Going in to alarm
The switch that is mounted to your key cylinder is most probably bad and it is not disabling your alarm when you open your door. this is the most likely cause, to get to it the door panel will have to be removed.
Dec 26, 2008 | 1999 Pontiac Bonneville
Honeywell Ademco Lynxr-i Lynxren-6 Security System Logo
138 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
