Question about Dometic Rooftop RV Air Conditioner
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
  • 3 more comments
  • gregf145
    gregf145 Feb 18, 2013
    Thanks for all the ideas. I am still working on it as a few things came up.
  • gregf145
    gregf145 Jun 07, 2013
    Thanks for all the ideas. I replaced the circuit board and run capacitor. It appears the compressor is shot. While monitoring the voltages, the compressor works, providing cool air. The lines are all iced up and everything works fine, for about 10 minutes. At that point the compressor starts pulling a bunch of amps and stops cooling. When testing there is 115v through the thermal cut/off on top of the compressor while it is cooling. But then the voltage is pulled down by the compressor. If I disconnect the hot lead at the compressor, line voltage returns to normal. The compressor then has a grounded circuit. Thanks Gregf145
  • Duncan Lawrie Aug 10, 2013
    sounds to me like your gas has leaked out
  • gregf145
    gregf145 Aug 26, 2013
    THE REAL PROBLEM IS: The bearings in the compressor are shot and after running for a few minutes, they get hot and freeze up the compressor. Thanks for all the ideas. With a defective compressor, it makes no sense to try and fix it.
  • gregf145
    gregf145 Jul 14, 2014
    My trouble with the air conditioner was burned out bearings in the compressor. After running a few minutes, the bearings would freeze up. The voltage would drop to near nothing and the amps went sky high. As it acted shorted out.
  • Dometic Master
  • 6,674 Answers
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Posted on Jan 27, 2013
  • 587 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 332 Answers
SOURCE: COMPRESSOR
Thermostat is bad
Replace it
Posted on Mar 06, 2010
  • 230 Answers
SOURCE: dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Posted on Jun 23, 2008
  • 92 Answers
SOURCE: 57915-341G9 AC. unit is tripping the 20amp breaker
Sounds like the compresser is bad,I have seen a freon overcharge also do this-but it is rare.
Posted on Sep 09, 2009
  • 415 Answers
SOURCE: AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Posted on Mar 31, 2010
Testimonial: "You gave us a couple extra ideas than what we already thought of checking. Thank you. We will trade out parts from working one, see what it is. Thanks"
Dometic roof ac mod SL135RB. Blower motor works fine. No cool air comes out
compressor not running. capacitors, thermostat, relay board all possible.
Oct 28, 2013 | Dometic Rooftop RV Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
Rv Roof top ac unit
Fan motor bearing getting hot and seizing on the shaft. Just changeout the fan motor...
Aug 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
2,247 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
