Question about Maytag Dryers
Have maytagdryer giving ts error code model#mdg9700awm
Giving ts error code
Samsung vtr error code t5 what is it
"Ts" error code usually indicates restricted air flow in the vent (could be internal or out of the dryer. In some cases could be the thermistor itself that gives out false reading.
Feb 11, 2015 | Samsung Dryers
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
Hello i got a maytag dryer model #mde6700ayw wont run and give me a code t5 what can ii do to fix that problem
I believe that your code is actually "tS" vs t5. TS is a shorted thermistor
From the repair manual.
tS = Dryer Thermistor Short Sensed
{The Thermistor resistance is very low}.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
- Check for diagnostic code 1
The thermistor is item 50 this link: PN 35001191
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174648&diagram_id=28603393#d28603393
The thermistor has to be shorted to the chassis to get this code.
Thanks for choosing FixYa,
Kelly
Jun 14, 2011 | Maytag Dryers
It gives a E1 Error Code and It is an Kikos Ts-73021 Tread Mill
replace lower electronics board and motor controller if applicable.
Apr 08, 2011 | Exercise & Fitness
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
My TS-L632N is giving me a Code 19 error on my HP dv6985 se Special Edition Notebook
From your description I understand that the DVD drive is not working and you have code 19 error in device manager.
Do not worry, run the following fix on the pc and then restart the notebook.
http://www.techiesspot.com/filez/cddvdfix.reg
Mar 16, 2010 | HP Pavilion DV6700T Notebook
Forgot code for Dolby system model no. AKL 1676 TS
http://codedradio.info/?i=bn&sb=D theres the site it shold be on there
Jul 31, 2009 | Car Audio & Video
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
