Question about Dewalt Sawzall Dw305 & 18v Impact Dc823
How do I replace the worm gear in a De Walt reciprocating saw model# dw305?
  • Gordon Kidwell
    Gordon Kidwell Jan 19, 2013
    This is a type 2 saw.
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
Model dw305 will not reciprocate perodically
Brushes are probably worn.
Dec 21, 2016 | Saws
De Walt radial arm saw old model 7740. Am trying to restore it to working condition Very difficult to change the height adjustment due to binding when trying to turn the handle on the top.
The manual for the saw is included below, To free the height it may be best to remove the saw carriage from the arm to reduce the weight.
Use WD40 or equivalent to cut the rust and a suitable grease to maintain the freedom. There is a worm screw that is below the cylinder that may need lubricating. The manual shows the assembly. I routinely apply 90 weight gear oil around the large tube where it goes into the housing,
http://vintagemachinery.org/pubs/252/1213.pdf
26351737-byjyd4kzhh1rgh2pqslbdjkq-3-0.jpeg Hope this helps?
http://vintagemachinery.org/pubs/detail.aspx?id=1213
Nov 12, 2016 | Delta Radial Arm Saw
Ryobi reciprocating saw motor rund but blade doesnt
A Ryobi might not have that nut. They are likley a ring gear drive which is different. I'd open it up and look at the gears. Make sure no teeth are missing and that none are worn down. If they're worn they would probably look rounded. If the gears are bad the saw is more than likely not worth repair. Ryobi saws are not very expensive compared to the cost of repair parts.
Mar 10, 2014 | Ryobi Rj165v Reciprocating Saws
De walt dc385
should come with a chuck key, or a key to lossen the blade. all of them lock in this manner regardless of manufacture. Check website of manufacture for this, or your mannal
good luck
Apr 30, 2013 | Saws
How do i replace the gears on a makita reciprocating saw
Expensive job. You have to replace the armature and the gear which retails around 110 pound alone you would be better buying a new one unfortunately.
Nov 06, 2012 | Makita Jr3000v Reciprocating Sawzall
How to change a blade on dw305 dewalt recirocating saw
On the DW305 you need an allen wrench to remove the blade. Some tools have one somewhere on the handle, if not find one to fit in the blade clamp hex-head bolt. Loosen the bolt and the old blade should come out easily. When you put the new blade in make sure the pin inside catches the hole in the blade.
Mar 07, 2012 | Dewalt Saws
Need to remove and then replace blade clamp on DW305 Type 1. how do you remove the blade clamp? I see two pins
Hello Hollister, on this peticular sawzall they are using a roll pin to hold the blade holder on. If you remove the blade clamp screw, you can move the blade holder back and forth on it. You will need to get a very small punch and drive it all the way out. Look at the picture below. You will need to remove (38) and (52). It will make it much easier.
I hope this helps. If you run into trouble, I'll walk you through it, just post back.
Dec 06, 2010 | Dewalt Saws
How do I remove the nose piece to repair the reciprocating shaft.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
May 12, 2010 | Craftsman 8 amp Reciprocating Saw with...
The blade on my Delta 36-540 table saw is jammed in the 'down' position. The turn wheel will not move it. Thanks Walt
Is there a 'wheel lock' on the shaft? You may have to dismantle the saw arbor mechanism to free the worm gear drive. If the saw has been unused for a long time and exposed to excess moisture, the worm drive could have rusted tight. Good luck!
Feb 08, 2010 | Saws
Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Mar 18, 2009 | Dewalt Heavy Duty Reciprocating Saw Kit
Dewalt Sawzall Dw305 & 18v Impact Dc823 Logo
69 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
