Question about MSI Ms-7104 Pm8m-v Via Socket 478 Intel Motherboard
The back panel of the board does not working. what shall I do?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
Get a new one
Posted on May 25, 2014
LG 47LN5790 TV went black screen, only audio work, show black screen. What part shall I order to fix it. how to look the right part to replace it, if I dismount the TV?
Back light problem. Check and replace the damaged components at its back light inverter circuit board. Contact any service technician. http://electronicshelponline.blogspot.com/ If you wish to get more details visit the site linked here.
Feb 06, 2017 | LG Televison & Video
Screen goes black, still have sound. Been researching for hours please HELP!
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 23, 2015 | Polaroid TDA-03211C 32 in. LCD HDTV
Panasonic TC-P54S2 red light 8 times
use this chart to help isolate the problem
Mar 06, 2013 | Panasonic TH Televison & Video
My sharp TV have encountered a green screen what shall i do?
Hi Rodolfo,
Your problem is internal, this is due to the following reasons :
1. Bad drive transistor on the neck board.
2. Mis-aligned trimer resistor on the neck board.
3. Dry joints on the neck board.
4. Tube is faulty.
5. jungle ic
Isolating the defective parts is technical. I've advice you to send it to repair shop to troubleshoot the symptoms.
Hope it may help you.
Thanks for using Fixya.
Feb 07, 2011 | Sharp Televison & Video
I have a Samsung Plasma TV (PN50A450) with sound but no picture.
Y board, Y-buffer board, or panel can cause this problem. Anyways, replace the panel shall be good, because those boards will come with the panel.
Apr 21, 2010 | Samsung PN50A450 50 in. Plasma HDTV
1/8 inch wide vertical streak on dell lcd monitor grey-green
There are loosed contacts between scaler board and flex-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flex-cables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, unscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flex-cable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Sep 12, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Left in the snow for a week
the board inside wil be damaged  try kepping it in charge for several hours  it must work if not then the  board has to be changed
Feb 15, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Dell Latitude D600 PC Notebook
go to the safe mode and login to the admin account and than go to control panel and user accounts and change an account select the account and than remove password and restart the system
Nov 01, 2008 | Dell Latitude D600 Notebook
Speedometer not working
speedometer get speed signal from ABS. ABS and DSC are two functionality in same ECU.
You shall read faults from ABS/DSC ECU.
Most frequently, there are problems with speed sensors on wheels.
With ignition on, you shall measure voltage on both wires (- pole of voltmeter shall be connected on vehicle ground). You will see one sensor without voltage supply. This will sensor with problem. you can, for check, change sensors on same axle (left and right).
Switch ignition off, and on.
If voltage supply missing will go on another side (with faulty sensor), you will be sure that is problem is sensor.
Jul 23, 2008 | 2002 Jaguar X-Type
172 will not work after dropping
Have you solved the problem?
If not you shall check that the flexible cable to the screen is securely connected to the circuit board. Check also the other cables.
BR
SHALL@tdc.dk
Oct 21, 2007 | Garmin GPSMAP 172 GPS Receiver
MSI Ms-7104 Pm8m-v Via Socket 478 Intel Motherboard Logo
27 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
