Question about Panasonic ER 147 Hair Trimmer
Need a blade for ER147 - Panasonic ER 147 Hair Trimmer
How to install blades
Almost all scroll saws use a 5 inch blade. You need to take all the tension off your saw before installing the blade. Make sure you are using the right kind of blade. Either it is a pinned blade or non pinned blade. Some saws can use either. Make sure the teeth on the blade is facing down toward your saw table. Clamp the blade into the blade clamps and then add the tension. You should be ready to go now
Jul 12, 2014 | Saws
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to lubricate blade assembly.
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
Adapter for panasonic hair clipper ER147
panasonic ER147 hair clipper adapter is AP-22290 charger power cord replacement recharge adapter 220 volt for panasonic er147 national or panasonic hair clipper.
http://www.menelectricrazor.com/panasonic-er147-charger-power-cord/
Jan 13, 2013 | Health & Beauty
How do i change blade
Under the mower,the blade is held by a single nut.Unplug the spark plug.Lift the mower.You will need to hold the blade.I use a large screw driver to keep the blade from turning as you remove the nut.Do NOT but a blade before you get the old one off.Some blades use a star shaped hole others use a round one.You need to know which you need,as one will not fit on the other.Once the nut is off the blade will come off too.Then just put the new blade on and the nut.
Jun 29, 2011 | Garden
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How to repair my hair trimmers?
I am a retired hairdresser and it sounds like one of three things or a combination. Your blades may be worn (dull) and need replacement , it may need to be oiled,the blades could be "misaligned" and need to be adjusted. You do that by removing the two screws holding the blades on, remove the blades, while you have them off, clean out any built up clippings in there and then put the blades back on. BEFORE you tighten down the screws make sure the "teeth" from the blades are lined up so the bottom blade teeth can be seen BETWEEN each top blade tooth. NOT directly on top of each other. Now tighten the screws. urn the clipper on and add a drop of clipper oil (no substitutes) onto the running blades. That should do the trick.
Jul 20, 2009 | Andis Outliner® II 04603 Hair Trimmer
Where I can buy er 147?
please i just wish to know where i can buy er147.i'm from belgium
Dec 21, 2008 | Panasonic ER 147 Hair Trimmer
Panasonic ER 147 Hair Trimmer Logo
24 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
