Question about Poulan Garden
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Poulan chainsaw p3314wsa
    Sergeant:
  • 322 Answers
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
Posted on Jan 17, 2013
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Posted on Jan 28, 2010
dontbother10
  • 2220 Answers
SOURCE: poulan 34cc chainsaw. wont start. replaced
Set the gap as Drallim suggests then follow this to test the ignition system, the entire system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode. HTH
Lou
Posted on Feb 24, 2010
Wont start
how old is gas? is it ethanol? do u have spark ?
Jun 25, 2014 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Nov 17, 2013 | Garden
Replace fuel line on poulan 1975
Hi Will...
I think this is what you need
Please take time to rate me
Bud
Mar 17, 2013 | Poulan 14" Chainsaw
Poulan chainsaw 35cc wont start. finish over hauling. new piston and compression ring. and already clean carb. it wont just start.
are you sure you have spark? check that first then check that the mixture screws are set right. you say the carb is cleaned. did you put a kit in it or just take it apart and clean it reusing the old diaphragm?
Feb 13, 2013 | Poulan Garden
My Poulan Woodshark 14" type 2 (-2 on serial
Fuelleaking from the cap will not stop it running, 40-1 with good quaility two stroke oil shoule be fine, if there is a good spark and fuel at the plug, you need to check that the piston has not picked up, the hottest part of the engine is the exhaust side, so remove the muffler, and take a look at the piston skirt throught the open exhaust port, any signs of scuffing and it will need to come apart to check the damage.
Oct 11, 2011 | Garden
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
My 1980 ski doo citation has good spart and great compression and is getting fuel but still will not run it wont even fire even with starting fluid i think its timing is messed up so how would i fix this
The problem may or may not be timing. You say it's getting good spark but is it great? if the compression is as good as you say and your spark isn't strong it can be put out by strong comp. if it is timing i would get shop manuel for it. i can't find a micro phish on it so i'm not really sure where to tell you to start.
Mark
C.C. Motorsports
Feb 14, 2010 | 1998 kawasaki ZL 250 Eliminator
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
Garden Logo
189 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
