Question about Porter Cable C2002-WKR 150 PSI, 6 Gal. Oil-Free Compressor w/13 Piece Hose & Accessory Kit
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
I have a porter cable 80 gal 6hp air compressor and the safety valve on top of the pump lets air out before the tank reaches its correct psi. The pressure switch is set to 175, however the safety valve activates at about 150 or even less. How do I fix it?
  • briank25
    briank25 Jan 17, 2013
    Is the spring loaded valve on top of the pump called a regulator or a safety valve?
    Problem Solver:
  • 8 Answers
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Posted on Jan 17, 2013
2 Suggested Answers
SOURCE: my porter cable c2002 150 psi gal compressor the
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Posted on Dec 20, 2010
Porter cable 6 gal pressure switch. safety valve blows when tank filling
Depending on the pressure in the tank when the safety valve releases,the problem is likely your pressure switch. If the pressure is at or above 160 psi when it blows, then the problem is the switch.If the pressure is lower, then it is likely a faulty safety valve. There are about 8 versions of this machine. check on dewalt service net for the correct part. you may need to check ebay if the part is nla thru dewalt.
Jul 06, 2014 | Porter Cable C2002 150 Psi 6 Gal...
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
6hp 25 ga. porter cable compresser, keeps running -blows, blowout valve, compresser works good new pressure switch? thanks ,scoop
Pressure switch can be adjusted to lower pressure (most are set between 125 and 150) however could be faulty safety valve if safety open below 165psi. Some things to check. Safey has pressure setting stamped on side. Check range of safety and compare to tank pressure when safety opens. Check that pressure switch contacts are not welded (unplug unit and remove cover to switch, look for contacts thru side of switch). If you suspect that switch is faulty, buy universal switch from ebay or other suppliers making sure of pressure range and fittings. Good luck
Mar 08, 2011 | Porter Cable Air Tools & Compressors
I have a porter cable 6 gal pancake 135 psi compressor. How can I change the cut off and cut on pressure. I've been trying to add air to my car tires and it will not fill the tire all the way up. I was...
where the plug in goes into the pressure switch you can take the cap off and you will see the electrical points and on the inside of the plastic cap it will you show you the two screws to adjust there. one screw will be to raise or lower the min and max pressure equally and the other is to adjust the differential between them. But make sure not to exceed recommended pressure of the compressor or you will blow safety valves, the safety valve will say what pressure it will go off at
Jan 18, 2011 | Garden
Compressor keeps blowing release valve
Compressor pressure switch not working properly. Remove cover over pressure switch. Drain air out of tank. pressure switch contacts should open. If contacts do not open they may be stuck or welded close. Remove power and gently pry contacts apart. If they where welded together this will correct. If this doesn't correct replace pressure switch
Jan 16, 2011 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
I have a Porter Cable air compressor model CPLKC7080V2. Air leaks from the pressure switch and aftercooler safety valve and the pressure switch before the compressor reaches 80 lbs pressure. I replaced...
I believe you have a head valve or piston ring problem. The parts you replace are suppose to leak. It is a safety feature that doesn't allow the motor to burn up before the pump warms up. Kind of like a soft start feature. If you look on the breakdown part number 107 Kit Valve Plate is what you need to inspect. Sounds like your valve plate is either worn or damaged. If you go into the pump you will have to get part 103 also which is a gasket kit. Or you can try to salvage the old gaskets.
If the valve plate is ok you will need to inspect the rings that go around the pistons. Some times you will get one that gets brittle and breaks off scarring the cylinder. Look for these two things, I am pretty sure one of them is the problem with your compressor.
Sep 06, 2009 | Air Tools & Compressors
Compressor blows off, does not maintain pressure
Hi there. This is normal. The pressure is set to stop at around 120-140 PSI as a safety measure. It probably kicks in again around 80 PSI so as to remain pressurized between 80 and 140 PSI. Since most air tools operate in this range, it is ok for the compressor to maintain pressure in that range. You do not want to adjust the maximum pressure safety release valve as it could be extremely dangerous as certain components in the compressor may only be rated up to 140 PSI or slightly higher before they fail or blow apart.
Jul 25, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Won't start -Porter Cable Cable 135 PSI, 60 Gal compressor
ARE THE POINTS BURNT IN THE PRESSURE SWITCH? DO YOU HAVE A LEVER ON THE SWITCH SET TO ON OR AUTO? IF YOU THINK ITS THE SWITCH JUST BYPASS IT AND TIE THE WIRES TOGETHER TO SEE IF IT RUNS. BEWARE YOU HAVE NO PRESSURE PROTECTION EXCEPT POP-OFF VALVE. MOST P.O.S. COMPRESSORS LIKE PORTER CABLE HAVE 3500 RPM MOTORS AND HAVE A THERMAL RELEIF BUTTON ON THEM. JUST PUSH TO RESET. MAKE SURE YOUR WIRNG OR DROPCORD IS LARGE ENOUGH GAUGE. SMALL GAUGE DROPCORDS KILL COMPRESSORS.
Jan 17, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable C2002-WKR 150 PSI, 6 Gal. Oil-Free Compressor w/13 Piece Hose & Accessory Kit Logo
445 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
