Question about Garden
Convert110v 600watt hps ballest to 220v
I have a 600 watt hps ballest i want to change it to 220 three wire where do the wires go
5 Suggested Answers
SOURCE: kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Posted on Feb 03, 2008
  • 2976 Answers
SOURCE: How to change wiring from 480 V to 220V connection
Here is the link for the manual. You will need the exact model AND the serial number to get the correct manual.
http://www.millerwelds.com/service/ownersmanuals.php
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Posted on Mar 09, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking dual fuel range wiring
You will need a neutral, ground and 2 wires carrying 120V each
Posted on Mar 11, 2009
Low voltage and hi voltage is just 220 and 110 can i still make the pump have two speeds
The 220v / 110v are the two wiring options on that motor. They usually come pre- wired for 220. The wiring can be changed to where it will run on 110. Be sure to get it right. if you wire a 110v motor to 220v it will go bang and die.
A two speed motor will have two hot wires, one common, and one ground (4 wires). Single speed will have three wires. You can't make a single speed motor a two speed motor.
Mar 01, 2015 | Pentair Pool & Spa
How to change 110v to 220v on sonance cinema 260 subwoofer amplifier
I suggest contacting the manufacturer as there may be an internal "reconnect" that would allow 220v operation. Good luck!
May 21, 2014 | Audio Players & Recorders
Wiring diagram electric hob
www.electroluxappliances.com/Owner-Support
Aug 14, 2013 | Electrolux E604-220V50HZ Model E604 Floor...
How can i change my 220V jet pump into a 120V jetpump?
Why do you want to?
You have to change the motor to a 120v model, same frame.
Service wiring has to have a hot, neutral and a ground. You should already have three wires so that is not a problem, just have to move one of the 220 hot wires to neutral. That will give you one hot, one neutral and one ground wire to make your 120V circuit.
If you only have 120V service and a 220V pump motor you can purchase a step up transformer that will take 120V in and give you 220V out. You must know the power in watts or KVA of the motor in order to purchase the correct step up transformer.
A bit more information about your situation would help.
Aug 19, 2012 | Plumbing
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
I am trying to wire a utilitech 70 watt hps dusk to dawn light. i have lost the installation directions. can you help?
Lumark makes a 70 watt HPS sold at Lowes
If this is your product:
Add a comment and tell me what color wires are on the back of the HPS, and what color wires you have, and what type of fixture you are replacing.
I will probably be able to help.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
May 09, 2009 | Electrical Supplies
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
Nov 04, 2008 | Remington HC-600 Hair Trimmer
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
