Question about Dewalt DW305 VS RECIPROCATING SAW WITH METAL CASE
Dewalt reciprocating saw with bad worm gear - Dewalt DW305 VS RECIPROCATING SAW WITH METAL CASE
SOURCE: Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Posted on Apr 23, 2009
  • 313 Answers
SOURCE: Dewalt DW303 reciprocating saw
go to www.dewaltservicenet.com look for the icon find it now.enter the model # of the tool & search
Posted on Sep 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Posted on Mar 22, 2009
SOURCE: I Have a Dewalt DC385 type 2 Reciprocating saw.
REMOVE THE BLADE !!!! take the handle apart and lift out the switch. keep track of the lock slide button and how it is installed. unplug the switch wires. carefully touch the wires you just unplugged onto the battery terminals. these wires lead directly to the motor. BEWARE.. if the motor components are good , the saw will run at FULL SPEED. you only need to tap the wires, DO NOT jamb them onto the battery. If the motor runs then most likely the switch is bad. If you know how to use a continuity tester then you can also check the switch. Bad moter likely culprtet is the brushes are crapped out.
Posted on Apr 04, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
Is there a fix for heavy vibration
Sadly dewalts vibrate a lot! They don't have the counter balance the the Milwaukee and Makitas do. My guess is it's fine. I'd check the four screws that hold the gear case to the body regularly to make sure they stay tight.
Mar 02, 2014 | Dewalt DC385B 18v. Cordless Bare...
Reciprocating
That sounds dangerous! Does it actually cut after you do that? It sounds like it has bad gears and wouldn't cut if you put pressure to the blade. On a dw303 it's likely not worth repair if that's the case.
Jan 23, 2014 | Dewalt Dw303m Reciprocating Saws
Have a Dewalt reciprocating saw , and when turned on oh my goodness the noise that it makes ! screeching !! any ideas ???
Not sure of the model you have, but my guess is you have a stripped crown gear and armature gear (Very common problem for these tools)
Oct 18, 2013 | Dewalt Saws
What type of grease is used in a dewalt reciprocating saw?
Harley, I use lithium grease in my power tools gear boxes, never have an issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Nov 19, 2012 | Dewalt Saws
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
Is the Dewalt dw310 multi purpose saw available in 110 volts
  • Help Instructions, Repair Guides, Manuals & Troubleshooting sacore:green.gif Dewalt DW310K Heavy Duty Reciprocating Saw Kit... Is the Dewalt dw310 multi purpose saw available in 110 volts - posted in Reciprocating Saws ...
    www.fixya.com/troubleshoot
  • Jan 14, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
    Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
    Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
    Have a great day.
    Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
    How to open the front housing of dewalt dc385 recipricating saw
    press release button and remove shoe on front of saw. Remove 2 screws on front end. Slide off rubber covering. To open gearbox remove 4 screws and pull off. Note, once open yo probably have to replace the gasket. If saw is jammed, try spray a penetrating oil in and tap shaft with a hammer using a wood dowel for contact. You can remove the 2 rubber plugs from the gear casing and pump in grease without removing the cover.
    Stephen Brown
    Jun 13, 2010 | Dewalt DC385B 18v. Cordless Bare...
    Mar 18, 2009 | Dewalt Heavy Duty Reciprocating Saw Kit
    Dewalt DW305 VS RECIPROCATING SAW WITH METAL CASE Logo
    Top Dewalt Saws Experts
    Parson's Repair...
    Parson's Repair...
    JOHN LAPIER
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
