How can i reset my acer aspire 7551 2560 to factory settings
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 40 Answers
SOURCE: How do I reset my Acer Aspire 5517 to the factory
click start menu, click all programs, look for Acer and click on it. Then click Acer E recovery. in a few seconds a window will come up. click the restore option in the left hand menu. You can restore to factory condition or restore windows and save your data. its all pretty much there in front of u. hope it helps u
Posted on Apr 05, 2010
Testimonial: "Thanks Robert...you are a lifesaver!!"
parinasragde
  • 526 Answers
SOURCE: how can i reset my
turn on your machine then hit del b4 the system starts...go to bios setting and locate the "set to default setting"..if it doesn't help,follow these steps; (you need a flash drive to do this) instructions: 1.Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive.
  • 2.Go to "Start" > "Restart" to reboot your netbook.
  • 3.Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load.
  • 4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen.
  • 5.Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted.
  • 6.Restore your saved files from the flash drive.
  • Posted on Feb 09, 2011
    • 356 Answers
    SOURCE: i need to know how to reset my acer aspire 6930 to
    A slightly different model requires pressing Alt+F10 at the start up and following the prompts. This will wipe the hard drive though, so back up everything important first. You can probably still get the data even if it doesn't boot Windows.
    Posted on Mar 17, 2011
    Fomat my computer
    Which OS you are using??
    To Format your laptop,you need bootable CD....
    Format steps for windows 7:- windows 7 format
    Format steps for windows XP:- windows XP format
    If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
    Sep 18, 2012 | Acer Aspire One PC Notebook
    Tip
    How to reset Acer Aspire 5315 notebook to factory setting
    There are two ways to reset the Acer Aspire 5315 notebook to factory setting which also means to reset it to the original setting.
    The first way to reset the Acer Aspire 5315 to factory setting:
    1. Log-in as Administrator (if you have more that one account on your notebook).
    2. Go to Start.
    3. Select All Programs.
    4. Then select Accessories.
    5. Press System Tools.
    6. After that, press on System Restore.
    7. A page will appear, press Restore My Computer.
    8. Next, press next to continue.
    9. A message will appear, press Ok.
    10. Press next to confirm the restore point.
    11. The system will be restored.
    12. Restart the notebook.
    The second way to reset the Acer Aspire 5315 to factory setting.
    1. Turn on the Acer notebook.
    2. Wait for a few seconds until you see the 'startup' process appears on the screen.
    3. As soon as you the 'startup' on the screen, press Alt+F10 for about five times.
    4. This will set the notebook automatically to factory setting.
    **Try these steps at your own risk. Make sure to save on a Pen drive or USB Flash Drive any important documents/files before resetting your notebook.
    on Apr 22, 2010 | Acer Aspire 5315 Notebook
    Reset to factory seting
    Unlike other laptops, Acer Aspire notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire One Netbook 8.9 to factory setting.
    Step 1: Before starting your Acer Aspire One laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
    Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
    Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire One is reset to factory settings.
    Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
    If you face any issue with your Acer Aspire One Notebook/Laptops/Desktop, feel free to get expert technical assistance at
    http://www.vtechsquad.com/acer-support/
    Jul 22, 2011 | Acer Aspire One PC Notebook
    How do i reset my whole acer aspire 3690
    unplug power and battery. This is a hard reset
    Nov 30, 2010 | Acer Aspire One PC Notebook
    How to reset myacer to manufact setting
    1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
    2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
    3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
    4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
    5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
    6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
    Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
    Restore to factory default
    Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
    Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
    If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
    Jul 26, 2010 | Acer Aspire 4315 Notebook
    Reset Acer Aspire One to factory settings--clean hard drive
    Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
    Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
    Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
    Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
    Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
    If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
    Dec 28, 2008 | Acer Aspire One AOA110-1626 Notebook
    Computers & Internet Logo
    179 people viewed this question
    David Payne
    David Payne
