Question about Denso 1992 Toyota Celica GTS Sport 2.2L Remanufactured Alternator
Where's my Fuel Filter on my 92 Celica GT 2.2?
Everyone says it's under the master cylinder, bolted to the strut body, but all I see is something that's about the size of a small coffee can that looks nothing like any replacement part I've seen (including the one in my hand).
  • 54 Answers
Just trace the high pressure fuel line back from the fuel rail. this will lead you to the filter. the high pressure line has no fuel regulator on it ( small pot with a vacume line on it) if it looks nothing like the one you have in your hand i'm guessing you have been supplied the wrong filter possibly for a 2.0 litre.
Posted on Jan 17, 2013
  • 1 more comment
  • Rick Perry
    Rick Perry Jan 17, 2013
    Thank You David. A little more detail needed: I noticed that there were four small lines ontop of the fuel line, only one line didn't go into this disc shaped thing. is that the line you mean?
  • Rick Perry
    Also, I'm nearly 100% sure it's the right filter because of all of the cross checking that I've done. The only thing that I'm thinking is that *maybe* I've got a California Emissions model. I dunno.
  • Rick Perry
    a'hem, I meant to say 'fuel rail' not 'fuel line'
Here's a link to where it's at.Here's how to replace.Here's the filters.
Jan 17, 2013 | 1992 Toyota Celica
Need a new fuel filter and do not know the proper place it exists
Your fuel filter is located under the hood, center, rear engine area, passenger side of master cylinder, mounted on firewall. I hope this helps you and good luck.
Apr 02, 2011 | 1990 Toyota Celica
I can not find the fuel filter on my 1983 celica
its on passenger side, under hood, rear side of strut tower, mounted on fuel line thats if your motor is a 2.4 liter/ 2-brl 4 cyl.
Jan 04, 2011 | 1983 Toyota Celica Supra
Where is the fuel line located on a 1994 toyota celica?
Fuel pump access port under rear seat. Line runs from there to firewall, to fuel rail. Filter mounted on left side of firewall. follow the line from the rail backwards to locate filter.
Jul 12, 2010 | 1994 Toyota Celica
I need to know where the fuel filter is on a 1997 ford probe gt
The fuel filter is attached to a bracket located in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir.
Apr 02, 2010 | 1997 Ford Probe
Where is the fuel filter on a 1990 toyota celica gt located
drivers side just forward of master cylinder and about 3 inches below it. real fun to work on if your elastic man. hope this helps
Nov 27, 2009 | 1990 Toyota Celica
Where is the fuel filter located
If this is a four cylinder, feel around under the manifold. There should be fuel hoses going under there. Toyota bolted the filter to the block on the passengers side and it's real tricky to switch out. Most people I know have moved the filter to the fender wall after they've gotten it out of there. The hoses will just reach and with a drill and some bolts it will stay put.
Aug 09, 2009 | 1985 Toyota Celica Supra
How to replace the fuel filter on a honda accod 1997
You can find this underhood on driver side's below brake master cylinder. You will need a new fuel filter part # 16010-st5-933
tools needed: 10mm, 17mm sockets, 17 mm wrench, 3/8 drive short + long extension,rachet, 3/8 drive 14mm crow foot , 14mm short line wrench
this is a bit trickier to replace but it is simple..some people do the whole job from the top, that is when you will use the 14mm short line wrench,,personally i have found it a lot easier to loosen up the lower fuel line from the bottom ,,, Anyho ....
# 1 remove gas cap, to relieve fuel line pressure
# 2 raise the car up and with the long extension , 14mm crow foot , loosen the fuel line at bottom of filter DO NOT totally undo the line at this time or you will get fuel soaked,, put a pan under car so fuel can go there instead of on the floor once you totally undo the line
# 3 remove the 17mm nut at the fuel rail,( top end of fuel hose going to filter ) do not loose the aluminum washer you need to reuse it
# 3.5 remove the 17mm bolt for the fuel hose at fuel filter,remove the hose
# 4 totally undo the lower fuel line but undo it from the top ( engine compartment)
# 5 remove the 10mm fuel filter bracket bolt,, remove the assembly . you might have to play with it a bit but it will slide up by the master cylinder
# 6 once out, remove the 10mm bolt that hold the filter in the bracket., install new filter, make sure to line it up on the slot
# 7 if you look at the body where filter bracket mounts, there is an opening , below where the mounting bolt is, make sure to install the lower bracket nipple inside that hole,
# 8 before you install the 10mm bracket bolt, start the lower fuel line , from the top , make sure to turn the nut a few turn to make sure it is not cross threaded. once line is started ok, mount the bracket on the body tighten the 10mm bolt,,
# 9 tightem the lower fuel line ,,
# 10 install the upper hose, make sure to use new aluminum gaskets, put gas cap back on
Start the car and make sure there are no fuel leaks
Aug 06, 2009 | 1997 Honda Accord
Negative camber
Hi...
On your Celica.
Check if the Strut is NOT bent.
Or if the car was not involved on accidente on the front.
Check the Comdittion of the Lower Ball joint, LOwer control arm.
Check if the Camber in your car is adjustable.
Removing the Tire and removing the Bolt that hold the Strut in position. If the Holes in the Strut are Like Oval, is adjustable.
But if NOT. Some Autoparts SELL a Camber kit. That include
New bolt and washers.
But if you Don't want to spend money on the KIT.
Remove the Tire , Remove the 2 Bolt that hold the Strut.
And make the Holes A little oval the holes .
Move a little at front and rear. For make the strut adjustable.
POSITIVE or NEGATIVE..
Ok I hope this help on your problem...
Thank you for use fixya,,,,,,
Aug 22, 2008 | 1995 Toyota Celica
Denso 1992 Toyota Celica GTS Sport 2.2L Remanufactured Alternator Logo
57 people viewed this question
Top Denso Electrical Supplies Experts
wadingriver
wadingriver
pontelemon
pontelemon
Jude24
Are you a Denso Electrical Supply Expert? Answer questions, earn points and help others
