Question about Dell Inspiron Mini 10v Netbook Computer
I have a dell netbook.And I've tried nearly everything to delete having an hdd password. Any ideas??
I accidently set an hdd password when my original password wasn't working. Now it is and I can't delete the hdd password. I can't figure it out.
  • Official Brand Answer
  • 560 Answers
Brenda French,
I did a search for this issue on google. Below are the results on how to resovle the hdd password.
How to Remove HDD Password
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jan 18, 2013
  • 192 Answers
SOURCE: Forgotten HDD password on Dell Vostro 1510
If it truly is the HDD password, Dell will be of no help to you, as they have no control over the HDD Password; the password is stored in a hidden sector on the HDD itself.
The only people that could help you with that is the manufacturer of the HDD, and odds are they won't help you. It would involve sending the drive back to the manufacturer, and paying them a heft fee to unlock it. It would be returned to you, but would be blank, as they have no way of knowing that the data on it truly belongs to you.
Today happens to be your lucky day however, as I stumbled upon what seems to be a very useful piece of software. There are many restrictions with it's use, so make sure you can manage this. It would involve you connecting your laptop drive into a desktop system in order to perform the task of unlocking, only works with certain drives, and has been known to not work on some Dell HDDs, amongst many other things. Link is below..
There is a reason people put passwords on the HDD, and that is for total security... Good Luck my man, good luck!
Password Removal Software
Posted on Dec 29, 2009
Testimonial: "Well, thanks for the answer and the suggestion ... I'll keep guessing at it until I figure it out or cave in and buy the removal software."
  • 3940 Answers
SOURCE: HDD password frozen
Run diags on the HDD (Fn+Power) Possible HDD failure
Posted on Jan 25, 2010
SOURCE: I have Dell inspiron 6000 Laptop. asking for Admin
Check your Motherboard you find a battery there please reset it again and all your defult setting will enabled.
Posted on Aug 19, 2010
SOURCE: I have a toshiba mini
Try the A-FF HDD unlock software .
Important note on Operating System compatibility:
HDD Unlock Wizard requires a 32-bit OS. It will not function under 64-bit OS.
Download HDD Unlock Wizard - 2,8MB
System requirements:
We recommend that you have at least 300 MHz CPU and 128 MB of RAM. 32-bit Windows XP or Vista is required.
Note: HDD Unlock Wizard does not support external USB and FireWire enclosures. Please attach drives directly to the motherboard.
for more information check this link ..here
HDD Unlock Wizard is a user-friendly application which allows you to easily remove HDD password. IDE and SATA hard disk drives are supported. Both User and Master password can be removed. Please note that while unlocking, HDD Unlock Wizard will erase and re-certify the drive, meaning to say all data in the disk is lost and not recoverable. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow removing an unknown HDD password and making hard drive usable again.
Posted on Jan 31, 2011
  • 53 Answers
SOURCE: Dell Studio 1537 to Panasonic Viera via HDMI.
Are the screen and computer sharing the same power supply, on a 4-gang multiplug or similar?
What else is plugged in to the same supply?
Have you got another HDMI cable to try this with?
How is the audio connected - can that be changed to test it?
Have you another laptop or PC that you can connect to see if this is the TV or the laptop causing the issues?
Posted on Jul 27, 2011
Dell Inspiron 1012 hooked up to television no audio
Right click on the volume tab in the taskbar in the far right and then click on playback devices. Check all of the devices and click set defualt and then try. Make sure you aux cable is plugged into the right port. Also mae sure all of the colors match on the tv to the cables.
Jan 31, 2013 | Dell Inspiron Mini 1012 Netbook...
I have a dell inspiron 1018 mini netbook that had windows 7 starter with linux/ubuunto partitioned with it. i tried removing the ubuntuu and it wiped it.(so it said) i booted it up with windows 8 and
Hi
have you tried going into the cmos settings to try and disable the password,
sometimes you can take out the cmos battery out to clear the password.
You may have to replace the hard drive, but the password may still be in the bios.
You can also google the problem and see if any one else was able to resolve the issue.
cheers
Nov 28, 2012 | Dell Inspiron Mini 10 Netbook
My acer is slow. has no memory but i've deleted nearly everything
You need to defragment your hard drive, try this program is free and do the job for you
And also you can use this program to see what prgram starts with windows and you can disable some of them to increase speed.
Oct 06, 2012 | Acer Aspire 5530G Drivers Recovery Restore...
I also have the same problem with may asus eee pc 1215b netbook. I dont know if i forgot the password of something has just gone wrong. Because the the first time i place a user and admnistrator password...
I had a similiar problem with a dell netbook. I had to boot up in safe mode, create a new account, then delete the account that would not take my password. That seemed to work. Couldn't tell you why the password was failing in the first place though.
Aug 22, 2012 | ASUS Eee PC Seashell 1215B Fusion...
Dell 1090 duo bios password reset
on some notebooks if you hold shift control then zero it should resset the bios passwaord to get back in.. serch the del site for your model nad it should give you tips on how to do it .. but i know for toshiba that is works remember contol+ shift +zero should reset pw.
May 13, 2012 | Dell Inspiron duo Netbook, Intel Atom...
My asus eee pc will not start windows. I've tried pressing F2 (and the bios screen comes up) F7, F8 and F9 ask me if I want to run system recovery, but when I say yes, it acts like it's about to...
Restart your computer..start tapping F8 quickly..if you reaches advance boot menu..there select repair my computer..then select the language..then enter your username and password if you use any..in recovery options you can try startup repair or system restore options..lastly if nothing works then select the factory image restore which will take your computer to factory settings but delete everything
Aug 24, 2011 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
Dell Inspiron Mini 10v Netbook Computer Logo
195 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
