Question about Xerox Office Equipment & Supplies
XEROX WORKCENTRE 428 ERROR U3-4
ERROR U3-4 XEROX WORK CENTRE 428
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed. Hope it will help you in some way of finding the fault. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 03, 2010
  • 196 Answers
SOURCE: Part list XEROX workcentre Pro 423/428
Try going to www.Xerox.com for guides and instructions. jackie
Posted on Jul 28, 2010
Error 010327 in xerox work centre 5222
That error signifies a defective fuser unit. Replace fuser, part number 126K24980.
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Feb 22, 2016 | Xerox Office Equipment & Supplies
Meaning of u3-3 in 428
http://www.omkarmin.com/pdf/workcentre-pro-423-428-printertec-23924.pdf
U3-3
(4133)
ROS failure
Abnormal power adjustment
value to the laser diode
when the diode is forced to
go on
POWER
OFF/ON
Jun 07, 2014 | Xerox WorkCentre Pro 428 Copier
Getting error code u8-3
Exposure lamp blown, lamp terminals contact or regulator
Cek Kabel Optic.
Aug 22, 2011 | Xerox WorkCentre Pro 428 Copier
I am using xerox work center pro428 .now it is not working error message showing code U8-3
Hi, I can't find that specific error code in the documentation on that model of machine, however, in general in Xerox machines U8-3 means that your exposure lamp is blown or has a problem
Aug 19, 2011 | Xerox WorkCentre Pro 428 Copier
Xerox workstation pro 428 error code 116-324
I did contact the Xerox support center and they did suggest the following fix:
reboot the printre --> pres the following buttons --> powersave + red stop button + nr 6.
This should empty the print memory.
Dont forget to remove all the printer jobs on the client computers.
Apr 30, 2011 | Xerox WorkCentre Pro 428 Copier
Error code U6-3
Hello, Assuming this error is persistent and a simple reboot will not clear it. This error means that there is an Memory Error. This might be caused by an improper grounding (earthing) of the machine.
To fix this error, in case the problem is not grounding, parts need to be replaced. So I would advise you to book a visit.
Oct 04, 2010 | Xerox WorkCentre Pro 428 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
12 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
