Question about Boating
1977 EVINRUDE 1977 9.5 9722M - Boating
2 Suggested Answers
  • 52123 Answers
SOURCE: Are 1975 and 1977, 55HP Evinrude outboard motors compatible
yes they are on most parts
Posted on Apr 26, 2010
The cover says evinrude triumph 70, the #317219 is on the head, the boat is a 1977. no where does it say johnson. where do i find any kind of info. on this 3 cylinder motor?
if you go google and type in evinrude you will see numerous references to johnson outboards , evinrude/johnson inferring that they are using interchangeable parts or are in fact the same outboard made in different countries
May 28, 2016 | Boating
What should the compression be on a 1977 115 hp evinrude
Russ, not sure on factory compression, forums say motor should be good if running 100+, more important is to be with in 10% from highest reading to lowest compression reading. Balance is a key part for engine to run good. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.iboats.com/basics/find_engine_compression.html
Two problems with 1977 Evinrude 115HP Two Stroke Need some help The Hull...
One Cylinder down on Compression
May 06, 2016 | Boating
I HAVE A 1978 EVENRUDE 35 HP NO FIRE TO THE PLUGS GREAT COMPRESSION???
evinrude 1978 -1979 have a capacity discharge ignition unit as the control for the spark system
it runs wires to an ignition coil
so I would be suspicious of that unit
check all connections for corrosion and bad connections
I typed in electrical schematics for 1978 evinrude out board engine and found a site --www.maxrules.com which in the list of schematics has 55hp 1977-1978
press on that and you get a schematics of the wiring diagram evinrude 1978-1979 55hp
now I am aware that you state that yours is 35 hp but if it has 2 cylinders then it is a fair bet that the wiring diagram will be the same
any way there are plenty of other sites that may be of benefit
Nov 26, 2015 | Boating
How to get trim on a 1977 evinrude to work?
quite possibly has no oil left in the system.if it is down now then the motor will not try to run to go further down .
Jun 15, 2014 | Boating
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
Apr 25, 2011 | Clymer EvinrudeJohnson Outboard Shop...
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Jun 15, 2009 | Boating
I need a picture of a 1977 evinrude 35 hp wiring. Can you help me
Google 1977 evenrude it will take you to numerous sites where you can download manuals for free.
Jun 09, 2009 | Boating
Boating Logo
35 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
