Question about Samsung HP-R5072 50 in. Plasma HDTV
How do you tell if y buffer upper and lower boards are bad
I have a fuzz all over the screen and to black lines on the right side one inches wide one inch apart but pictures comes in and fuzz every were are my y buffer boards bad ?
  • Samsung Master
  • 2,494 Answers
Could be the screen if it,s a plasma.
Posted on Sep 28, 2016
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
SOURCE: Y Upper Board
It looks like GUEST is a little anxoius about your helpful forum here.
Posted on Sep 24, 2008
SOURCE: Black 3-4 inch wide Stripe
Contact Samsung and demand a replacement television. With my situation, they had me take it to a repair shop and get an estimate. I was originally going to get nothing, then after several correspondence, only the parts for free since it was out of warranty (not too far out of warranty) and pay for labor. They decided it would be too expensive and difficult to find the part. They ended up letting me pay 350 for the same tv but 2 years newer. It is definitely worth the price since the labor alone would cost that.
Hope this helps!
Posted on Oct 26, 2008
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
Samsung 53" LED TV ....4 yrs. old. ....has thin horizontal lines (1 pixel wide) across entire screen
are the lines going left to right or up or down? if up or down probaly a bad panel,iff left or right either the upper or lower buffer board is bad
Nov 28, 2014 | Samsung Televison & Video
My 50 inch vizio plasma tv has a 7 inch blue line down the center of the screen and there are a couple white half iunch lines in the center of that. if i hit the input button it will disappear and then...
Since the lines are vertical, the image is lost sideways and the corruption changes with the image then clearly this is a sign of Y-Sus failure, not the Z-Sus or the buffer boards.
An logic or input board failure would affect the entire screen, not just a part of it and a failure in one of the buffer boards would affect strictly defined lines of pixels and the defect would be constantly there all the time.
Since you haven't told us the exact model i can't point you to a replacement board.
Aug 06, 2011 | Televison & Video
I have a vitical black line about an inch wide on the right of the screen - Can this be fixed? Phillips matchline flat screen tv
Usually it is not fixable, but sometimes there could be bad connection in x-buffer board or bad board.
Oct 10, 2010 | Philips Televison & Video
If the line is less then 2 inches wide this us a good indication of a bad PDP panel (Screen) usually very thin lines indicates a failure in the screen itselg, altho you might try replacing the upper and lower buffer boards to ensure its not the screen. You might want to take off the back and try reseating all connectors leading to the buffers and the Digital board. But in my experience thin lines less then 2 inches usually results in a bad PDP.
Jan 30, 2010 | Televison & Video
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
Vertical black line, left of center screen, 3 inches wide appears when plasma tv is cut on.
You either have a bad buffer board or a plug that has gone bad. Being that the line is that wide I would almost bet that the board is bad. Have a repair shop check it out. Thanks
Oct 22, 2009 | LG Televison & Video
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Phillips 42 inch Plasma -Screen Issues!!!
intermittent loss of picture on either bottom or top half of screen is specific to y buffer boards located on left side of screen going from top to bottom when looking at back of tv. the y lower buffer would be the board to replace to resolve the loss of bottom half of picture. if the top half also is going out intermittently could tied to upper buffer as well but just a note the y main board to right of these buffers drives those two boards so in some cases could also be part of the problem. if only bottom half is affected i would recommend replacing lower buffer only
Aug 07, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320 42 in
you have a bad display call a tech to conferm this it could also be y buffers
Dec 03, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Vertical line on screen
It sounds like you have a bad cable coming off of your Plasma Screen that goes into one of the buffer boards or a bad buffer board (Hopefully the latter which is easily replaced but most likely not!) I have run into the same problem and there is an IC made into the cable that goes out and would be very difficult to repair if it is even possible.
Nov 11, 2007 | RCA Scenium PHD50300 50 in. Plasma...
Samsung HP-R5072 50 in. Plasma HDTV Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
