Question about Pioneer PDP-5060HD 50 in. Plasma Television
TV Guide System not working
Our TV Guide system worked fine from the time we bought the tv until it was inturrupted by the installation of a HD cable box we used for the past 15 months (which brought in the Time Warner TV Guide.)
We recently discontinued the HD service & though it looks like all the set up questions are answered correctly, and we've waited the 24 hrs (several times), the clock is not the right time and the TV Guide still is not working. Hope you can help figure this one out!
  • 8 more comments
  • ruthdrn Jan 24, 2009
    The only questions it asks in the set up is for our zip code and which cable is the input plugged into - I don't see any place to "select a PBS channel". I called Time Warner & they said to contact the TV manufacturer. I feel like something just isn't set right, like I'm overlooking something - I really don't think it's the TV (though I have been known to be wrong before . . .) Can someone who is familliar with this modle talk me through it & help troubleshoot this by phone?
    We do not have a cable box now - just the tv(plasma display), the receiver, and a vcr, which we do not need to have involved (for recording purposes to the TV Guide feature).
    The TV Guide On Screen System is a free, interactive on-screen television system that comes with the Pioneer System. It worked fine when we got the TV, and we were just subscribing to basic cable at the time. When we upgraded to the HD, we got Time Warner's TV Guide, which was different.
    We do not have over the air antenna - we have standard cable
    I appreciate your thoughts, but I'm quoting from the manual - the TV Guide system is a free interactive on-screen program guide with this TV. For more info see www.tvgos.com. It says the only thing it doesn't work with is with satellite service. I'm thinking the problem has to do withg the set up somehow, 'cause even the clock is wrong.
  • ruthdrn Jan 25, 2009
    Thanks for your comments - I'll contact the cable company again to see if they can help. Meanwhile - if anyone has any other ideas, please let me know. Thanks -
    Yes, that sounds very familiar - the zip code is correct, the cable in - ant"A" - no recording device associated with it - sounds simple enough, but we're getting no data, after several attempts & overnights with the TV off. Wish there was a Pioneer expert nearby to make a house call!
  • chipdyer Mar 19, 2009
    I have the same problem with my Pioneer PDP-5060HD. my TVGOS just stopped working last Thursday after working fine for 2 years. I have HD through Cox CT on CH A w/cablecard and Ant on CH B.
  • twb311 Mar 19, 2009
    I have the same problem with my Pioneer PDP-4360HD. My TVGOS just stoppedworking last Thursday after working fine for 2 years. I have standard cable through Time Warner on Ch. B and OTA antenna on Ch A. Here is the response I received from my PBS affiliate in Kansas City
    "Your viewer is right--TV Guide uses a small part of our digital streamto put out this digital guide. It's a remote box installed downstreamin our plant, so unless we're completely off the air, there's nothinghere that should be a problem. TV Guide reaches in over the internetand does all the work inside the box remotely. I went down and lookedat it with our chief tech guy and he says that it appears to befunctioning normally. Lights were on and green on the box, but afterthat, we wouldn't have any real idea for sure cause we don't haveaccess inside the box. That's about the extent of my knowledge on thisone. And remember, we're not really experiencing any digital transitionper se--we've been up and running digitally for some time. We aregoing through a serious transition in master control as we put in theequipment for automation, but that shouldn't hurt anything downstreamfor us."
  • txkwall Mar 31, 2009
    I have had TV guide channel for about 22 months. Lost TV guide service about 2 or 3 weeks ago. Went through the setup about 10 times. Called cable one. They said not their problem. Called Best Buy, where I bought the system. They took me through the set up again. No help. I have a Pioneer PDP-5071HD television, a Yamaha DVD player (DV-S5950) and a Yamaha Receiver (RX-V461). Please help me!!!
  • 2,296 Answers
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Posted on Jan 24, 2009
  • Sheila Killian May 13, 2012
    I have no cable box. the cable itself is connected directly to the tv. TV guide has not finished processing in 4 months
  • 362 Answers
You must have the cable connected to the ANT/Cable A IN input on the reciever.
  1. To set the time:  Press HOME MENU.
2 Select “Tuner Setup”. ( / then ENTER) 3 Select “Clock”. ( / then ENTER) 4 Select “Time Zone”. ( / then ENTER) 5 Select a time zone for your area. ( / then ENTER
Let me know if this helps. Lone99star
Posted on Jan 25, 2009
  • Jason Morris Jan 25, 2009
    Check with the cable company, when you downgraded to basic cable you no longer recieve the digital information that the tv guide requires.
    I have been through the manual many times and you seem to have everything connected correctly.
    Without the digital cable box you are not recieving the signal required.
    Let me know what the cable company says.
    Lone99star
  • 108 Answers
In times past that information was supplied by your PBS station. You would have to select that channel when setting up the guide. Some cable companies are blocking that info because they want their customer's to subscribe to their premium services. Try selecting that PBS station.
  • Pioneer Master
  • 19,396 Answers
If you have not solved the problem yet, call the provider that sent you the cable box, and ask them how to set the TV Guide System using this receiver box.
Posted on Jan 26, 2009
  • 4,806 Answers
Hi there
Make sure the time and date is correct, get the manual, Once you set up the TV Guide On Screen™ system it may
take up to 24 hours to begin to receive TV program listings.
Receipt of all eight days of listings may take up to one week
(see Screen 14). In the manual
Good luck
  • 10,515 Answers
I would check, if there wld be diff. solution other than what the experts gave u, i wld post that.
Thnx.
  • 11,896 Answers
Initial TV set up leads you to the Welcome screen.
Or press TV GUIDE to begin setup.
• The Welcome Screen lists features in the Guide.
• Press ENTER to display Screen
Screen 2: Enter ZIP or Postal Code
• If you selected USA in Screen 1, you see the ZIP Code screen.
• You input numbers by either
• pressing the number keys or
• pressing / to display a number, and then / to
move to another field.
• Press ENTER to display Screen 3.
Once you start the setup procedure, you cannot return to the
previous screens. If you realize you entered incorrect
information, continue with setup. The last screen of the
procedure gives you the opportunity to correct any mistakes
before you exit setup.
  • Nate Stansfield
    Nate Stansfield Jan 26, 2009
    Just wondering if you had given a try to my solutions?
    Brigadier General:
  • 5,158 Answers
The tv guide has nothing to do with your tv... it's the cable service and the cable box that are at issue.
Robert
  • 177 Answers
Hello and welcome to FixYa!,
It sounds like the Manual is a Saviour in setting up the Guide!
Use the guide and scan for channels to use as a guide!
Hope this works, --P3NGYJ03
    Genius:
  • 2,920 Answers
The hd service is what gives you the programming guide.i have hd on my tv and if i were on basic cable i would not have the programming guide anymore. i go throgh dish network for my services and it has the on screen programming since its all hd
    President:
  • 1,214 Answers
Do you have an Over The Air (OTA) antenna connected? Tech 1819 is correct about the info for time coming from the local PBS station. But guide info I believe comes from the individual broadcaster. If your still getting signal via basic cable, what Ronnieh49 says makes sense. But, if you have an OTA antenna, you can get what the broadcasters send.
  • Mark Egan Jan 24, 2009
    I am going to say that I bet the TV guide system in the Pioneer was temporary, or, somehow it was inactivated, and needs to be reactivated. But I bet it was short term and requires payment to somewhere. TV Guide can not afford to set-up a broadcast tower in every city all across the country for the Pioneer receiver to get the audio AND video information (unless the Pioneer is hooked to the internet somehow, and again, in which case I would think was a temporary free trial.).
    You might look at an OTA if the wire is there and your close enough to broadcast stations. I am certain your TV has multiple input's for A/V signals, and the cable box would connect through HDMI or other means, and the OTA would connect through the 75 ohm coazial connector.
No sound through HDMI cable to hd Tv
Right click your sound icon in the bottom right hand side of your computer and go to playback devices right click HDMI output and set device as default and vice versa when you detach HDMI Cable
Feb 08, 2010 | HP Pavilion dv9000z Notebook
My toshiba 62 in.HD tv with cable card did receive the built in TV guide with cable chanel number and a brief description of what the program is about untill May of 2009. Comcast has repetedly told me to...
the tv guide is kind of like a computer application. so the cable box can run that application or function. the cable card is an add on to your digital tuner which allows for the bits/codes to be descrambled. there are so many manufacturers of cable tv converters that it would be nearly impossible for sony or panasonic or toshiba to have an internal operating system to run the guide application. you may have bought a mac but the service is written in windows, for example. unfortunately the technology is simply not there for a cable card to do more than unscramble the digital signal. and inside that cable box from the cable company IS a cable card.....
senior technician
quality control supervisor
telephone installation trainer and supervisor
Field Supervisor
Hey I just work for these guys at Charter, i think they **** too.
Jan 17, 2010 | LG 26LX1D 26 in. LCD HDTV
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Blue ray disc player is working fine, but the tv is not showing any channels. We are just installing our new tv. What did we do wrong?
I just bought a samsung BD-P4600 and I tried to connect with a Philips Plasma TV. What channel do I need to put it on for it to show?
Sep 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Will not play without using HDMI cable
  1. Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the AV Cable into the yellow Composite port for video, and into the white and red audio ports (if your TV does not have the red port, simply ignore it) on the back of your TV.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
Watching T.V. with speakers
Component 1 on the TV is probably an input, not an audio output. You need to find out if your TV has audio output jacks.
If I'm mistaken, and you are using audio output jacks from the TV, then you just need to press FUNCTION on your remote until the LCD display says "TV/VCR".
Apr 28, 2008 | Sony DAVHDX265 System
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Pioneer PDP-5060HD 50 in. Plasma Television Logo
719 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
