Question about Kyocera Office Equipment & Supplies
Failed to send via SMB
On a Kyocera copier we are getting a Send Error on the Copier stating Failed to send via SMB...check the SMB settings...>Login username and Login password,,,If the sender is a domain user, specify the domain name, host name and path
  • Kyocera Expert
  • 337 Answers
What model copier? What error code? What OS?
Posted on Jan 30, 2013
sir fixalot
  • 146 Answers
SOURCE: Kyocera Copier Password (KM-4050)
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
Posted on Nov 18, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Asking user name and password in Ricoh Aficio MP2000 copier
Pull the litium battery off of the printer card and put it back in. That may reset the password unless it wrote it to the hard drive.
Posted on Nov 20, 2008
SOURCE: kyocera cs 1820 error 2102 using ftp
I reset the IP adderss to another printer on the network and it worked so it looks like not all printers are compatable
Posted on Jun 17, 2009
krizanto81
  • 65 Answers
SOURCE: I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Posted on Jun 27, 2009
  • 36 Answers
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Posted on Apr 09, 2010
Document scan to SMB for w8.1 pro for
That model does not support scan to smb
the only scanning it support is
TWAIN (scan-to-Pc and Scan-to-Email only via Software QLINK
Aug 19, 2014 | Kyocera Mita Olivetti D-Copia 163Mf...
C2102 error code
2102 is a scan error. it depends on what protocol you are using (SMB, SMTP, FTP?) but check the TCP/IP info for the copier and make sure the DNS servers are correct. Try using IP addresses instead of URLs or hostnames to eliminate DNS resolution issues. Check username and password for authentication processes. See the operations guide for details on setting up scan
Dec 30, 2013 | Kyocera Office Equipment & Supplies
SMB
check if there's an error code in the completed queue.
Also it would be helpful to know what kind of operating system is on your computer since MAC and Windows 8 are not that easy through SMB.
Check if you shared the file on your computer to full acces rights
May 28, 2013 | Konica Minolta Bizhub C454 Color Copier
Hi Am having kyocera 4050 b&w Copier i have problem with my scan its showing the error code is 1102 can u help me
Here is what an 1102 error is and what some of the things to look for are.. hope it helps..
1102 SMB(SMB)
Error: User/Password or SharedName/FolderNameDomain name not entered as Domain UserInput
User Name with one of the form "Domain\User", "Domain/User", "User@Domain"SMB)
User Name/Password or Shared Name/Folder Name ErrorSpecify invalid User/Password (includes unspecified)Input correct User Name/PasswordSpecify the User who is not permitted for accessing to the folderInput correct User and Password
Check access limit for send destination folderSpecify invalid Shared NameInput correct Shared Name
(See the reference for the symbol which is possible to use for Shared Name)Host Name ErrorCheck if any prohibited letter (see the reference) for Host Name is included or notSCAN TO EMAIL(SCAN TO EMAIL)
User Name/Password ErrorUser ID for Authentication is not entered/entered wrong User ID
Wrong Password for Authentication is enteredInput User ID/Password which is used for Authentication from [Advanced] on Command Center correctly
([Login User Name] on [POP3] page or [SMTP] page)
It's actually related with SMB.
The shared folder on the server may be blocked by an open ghost connection.
A restart of the samba service may repair
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Office Equipment & Supplies
I'm trying to use my Sharp AR-M355N as a scanner for the first time. I've already made sure it's properly hooked up to the network and have successfully printed to it. I scanned a test page, put in the...
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
Aug 26, 2017 | Sharp AR-M355N Copier
CS-1820 Send function not working. Error Occurred; Results "NG"
Upgrade the firmware and the diver software, that will help you to fix the problem.
Jul 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Scanner will not process and send data to (network) computer.
1)check directory of smb file from the send mode func
2)check your login password from your pc and the computer name must syncronise with the machine login password.
Sep 09, 2009 | Canon ImageRunner 2030I Black and White...
SMB Scanning
I had the same issue and fixed it by adding the group "Everyone" to the shared folder permissions (where I was sending my scans) and assigning the "Everyone" group rights to "change" and "read".
Mar 30, 2007 | Konica Minolta bizhub C250 All-In-One...
2,051 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
