Question about Vehicle Parts & Accessories
Window control window on the driver side does not move up or down when you push the button on the control
  • 60 Answers
Either bad motor, bad switch, or not getting connection to power. Check the plug on motor and switch.
Posted on Jan 22, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Driver side window does not move up or down
Sounds like power window motor is bad in the drivers door
Jan 17, 2013 | Vehicle Parts & Accessories
None of my passesngers can unroll their windows
Make sure the Child Lock is off on the driver's side window controls.
Aug 09, 2010 | 1996 Ford Crown Victoria
I am troubleshooting the driver's side power window controller. Driver's window does not move up/down. Seems to be a problem inside the controller on door panel. Need help taking the controller apart,...
Ive installed alot of after market stereo equipment in these types of vehicles, usually to get to the switches you have to remove the door panel, and unscrew the two retaining screws that hold the switches in place, disconnect the wire bundle from the switches, press the retaining tabs on the side of each switch and push them out of the holder. As far as the cover that covers the switches it usually just pops off as it is being held in place with a positive retention spring tab. Before attemping to push out make sure there arent any retaining screws that hold the switch cover in place. Hope this helps.
Aug 07, 2010 | 2000 Chevrolet Suburban
When the driver's side window button is pressed, there is a "click" sound from the window motor but the window doesn't move.How do I check the window motor and/or the control console?
While holding the button in the down position with the key in the "on" position tap on the window motor with a hammer. Or if the window is down, hold the button in the "up" position. If window starts working when you do this there is most likely a bad spot on the armature in the window motor or the brushes in the motor have worn out. Hope this is helpful. Good luck.
May 23, 2009 | 2000 Ford Mustang
2003 F250 Power Windows won't work
check fuses 35 & 41 (10 amp, red).
it also shows an accesory delay relay in the fuse panel.
And fuse 601? 30 amp.
make sure you don't have lock-out on driver switch panel activated.
Power Window System
Features and Operation
NOTE: The accessory delay feature will allow power window operation up to 10 minutes after the ignition is off or until a door is opened.
If equipped with power windows, the window control switch (14529):
  • will operate the power windows only when the ignition switch is in the RUN or ACC position.
  • is located on each front door trim panel, and Crew Cab and Excursion rear door trim panel.
  • may be used to raise or lower the driver side, passenger side and rear windows from the LF control on the driver side, or the passenger window from the passenger switch.
  • includes a one-touch down (OTD) feature for the driver door window.
  • can partially lower the driver side window when the LF window control switch is depressed half way (first detent).
  • will completely lower the driver side window when the LF window control switch is fully depressed and then released (second detent).
Power Window System — Modes of Operation
There are two modes of operation for the power window system.
Manual Mode
When the LH window control switch is pressed to the first down position, the window will move down until one of the following conditions are met:
  • The LH window control switch is no longer in the first down position.
  • The LH window control switch is pushed to the OTD position, causing the windows to enter auto mode.
Auto Mode
Auto mode provides the OTD feature. The OTD feature is activated when the LH window control switch, for the LH window, is pressed to the second down position.
Auto mode will be terminated when any of the following conditions are met:
  • The LH window control switch is pushed to the UP position.
  • The LH window control switch is released (OFF position) and then moved to the DOWN position (first detent) or OTD position (second detent).
  • Note: Delayed accessory feature must be active.
The OTD feature is controlled by the window control switch.
Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • LF window control switch.
  • Accessory delay relay.
May 23, 2009 | 2003 Ford F250 Super Duty Crew Cab
2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Nov 25, 2008 | 2004 Jeep Grand Cherokee
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
