Whirlpool Duet washer: the default water temp is warm and I always use cold. Any way to make cold the default water temp?
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Posted on Aug 20, 2009
emissionwiz
  • 76164 Answers
SOURCE: cold water does not always flow into washer in whirlpool modelLSR
most common cause is the cold water solenoid valve at the back of the washer is defective
Posted on Sep 18, 2009
I am getting warm water when we have selected colc/cold. I have checked the cold water intake and it works. In fact, if I shut the hot water intake, I only get cold water for the wash. What is causing...
If you turn off the hot water line, and you have cold water then suspect the water inlet valve. Unplug the unit and turn off the water to disconnect the water hoses. Pull out the washer and remove the back of the unit by the water hose inlet. The new valve is around $65.00 and is on connectors, which make it an easy fix.
Feb 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool washer GHW9150PW0 and it always washes on hot water, no matter if I set the temperature on cold. I turned off the hot water faucet and still the wash comes out warm. What is the problem?
these washers sense the water temperature that comes in to them and automatically adjust the temperature by turning on the hot and cold valve on make sure both your water valves on the wall are on all the way and water is coming out of each
Aug 19, 2010 | Whirlpool GHW9150 Duet Washer
The code f 20 flashes on my duet front load washer what does this mean
The F20 code for insufficient water going into the machine. Checked the hoses and water valves at the wall to make sure high pressure water is going to the washer.
You can try a different Cycle water temp setting. Like Cold/Cold or Hot/Hot to see which valve is not letting in the water.
There has been some know failures of the cold water inlet valves. That Whirlpool part number 8540751.
I hope this information has been helpful.
Good Luck.
May 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I bought this washer used with out a manuel. I
Hello-I came across this several years ago. Some whirlpools have a preprogram where the water temp. is already defaulted to the type of load and color. As you assume the white should be hot or warm. The rest of the selections are probably cold. The manufactures can be driven to apply energy saving features into their products so most cycles are probably cold. If all else fails, when you make a selection let water fill into the tub about 5 minutes and carefully check to see if the water is warmer or colder. You also might be able to pull up owners info on the net if you have the model#.
Feb 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
Cold water does not always flow into washer in whirlpool modelLSR
Sep 18, 2009 | Washing Machines
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer
It sounds to me like your water hoses are hooked up reversed. Check to make sure they are correct. you can use a garden hose to run it outside so you don't make a mess, or just use a bucket.
Jul 20, 2009 | Whirlpool Washing Machines
Whirlpool duet sport
if its new top loader needs water temp switch need more infor "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
Try reversing the water fill hoses
Jan 05, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
No cold water on cold settings
Try switching you hot cold inlets to the washer on the back....If that doesn’t work let me know...
cbinny1
Jan 04, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
