Question about Whirlpool AWM5125/1 Front Load Washer
My washer gets so far then says fp
As said my washer keep sayin fp and red light on clean pump
  • Anonymous Feb 20, 2009
    Clean pump light keeps coming on, and I can't find our manual to work out how to fix it!
  • 41 Answers
Fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Posted on Jun 12, 2010
I have AWO3761 and increasingly frequently the clean pump light is lighting up and FP is diplayed during the wash cycle. The machine is still full of water so I empty it and take the filter out which is...
check your drain hose sometimes coins get through the filter and get into the hose also the pump may be bad the impeller sometimes break and it will not pump out the water
Jul 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
My washer wont spin keeps sayin CLEAN PUMP????? not sure how to do this HELP
you may have a hair pin, coin or sock in the pump that has blocked the pump or maybe keeping your pump from turning properly. I recommend getting a tech to fix this.
Jul 02, 2009 | Whirlpool Washing Machines
Clean pump
front load washers have a catch basket befor the pump that is easly removed be hind the lower pannel allways un plug appliances be for removeing any covers sears and partselect have some diagrams that may help you will need the model #
Jul 01, 2009 | Washing Machines
FP GLW10spins but clothes are still wet and lights/beeping are on
Most likely your filter is blocked, check out where this is and clean out well. Second there could be block in your exit pump preventing the water from being pumped out. If possible call or see your dealer for help, but you could do the thing yourself. You can click on troubleshooting above in blue. There should be several solutions for your model. The washing machine companies do not tell you how to do these things, so they can send in their techs to make more money.
For new buyers - ASK WHERE THE FILTER IS, WHAT ARE THE VARIOUS CODES, SERVICE. Where is the tech sheet?
Feb 26, 2009 | Fisher and Paykel Fisher & Paykel Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Dec 14, 2008 | Washing Machines
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
584 people viewed this question
Dan Webster
Dan Webster
Sal De
