Question about Vizio Recertified - 47" Class 46.96" Diag. 120Hz LCD HDTV SV470M
Where can i get a new screen for my 47"vizio hdtv
  • Vizio Master
  • 933 Answers
Ouch, will most likely cost as much as a new set. You can try Shopjimmy.com, retechtv.com, or EBay.com
Posted on Jan 20, 2013
  • 1779 Answers
SOURCE: Vizio 47" remote
If your manual buttons on the set do not work, then I would return the set. If they do work then contact the store on where to get a warranty replacement remote, or just go back to the store with the remote and see if it works on another Vizio.
Posted on Jun 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Hello there. My son hit my 47 in flat screen LCD
The screen is the most expensive part of the whole TV, save money for new set.
Posted on Dec 07, 2009
  • 148 Answers
SOURCE: If my 47 inch vizio has been cracked can I just
Yes you could, but a new screen, though easy to install, is very hard to find, let alone for less than a new tv. It is most likely going to be way more efficient and cheaper buying a new/used unit.
Posted on Feb 03, 2010
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
  • 5102 Answers
SOURCE: How can you tell if the bulb on a vizio gallevia
LCD TV's don't have a bulb. They have backlights (usually compact fluorescent tubes) and a panel of LCD pixels. So you can have one of three things fail: the video board, the inverter that drives the backlights or the backlights themselves. If the problem happened suddenly the inverter is more likely to have failed. As the backlights fail, the screen slowly dims or the image will become pink/red. Look closely at the screen, if you see a dim image then the backlight has probably failed (block the room light but try looking with a flashlight from a few inches away from the screen). If you see nothing, the inverter or the video board are more likely suspect.
For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Sep 22, 2010
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
What is a main PCB
PCB stands for: Printed Circuit board.
Nov 01, 2012 | Vizio Televison & Video
I just cracked the screen on my 47 Vizio LCD HDTV. Can It be replacement?
Sorry to tell you but the display panel will cost more as a part than the set did when purchased.
If you purchase a new set some stores offer insurance for this but remember mfr. does not cover this fatal damage as it is considered avoidable.
sj
Sep 09, 2011 | Vizio GV42L 42 in. LCD Television
We have a Vizio LCD HDTV 47" Flat screen TV. We
You can try the special cleaning napkins for laptops, you can buy them in every electronics shop. Operate very softly avoid pressing on the TV surface. If even that doesn't help, well, it will remain like this, because of phisycally damage.
May 18, 2011 | Vizio VO47L 47 in. LCD TV
My Vizio SV472XVT 47" HDTV
Unplug the TV from the wall. There must be something wrong with your circuit board. Call customer service for what to do to fix your TV or get a new one.
Mar 05, 2011 | Vizio SV472XVT 47 in. LCD HDTV
Dec 07, 2009 | Vizio GV42L 42 in. LCD Television
Vizio screen
try this website: www.shopjimmy.com
Mar 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio Recertified - 47" Class 46.96" Diag. 120Hz LCD HDTV SV470M Logo
60 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
