Question about Electrolux Ovens
Vent door will not stop opening and closing
I have electrolux icon model no. E30MH65GSS, which I bought 4 months ago. This is the 3rd time that the vent door will keep closing and opening without being functioning. I have even disconected from the wall wait a while but still doing it.
What can i do?
    President:
  • Electrolux Master
  • 2,651 Answers
Its 4 months old??? call for service this is an issue that electrolux will need to rectify for you, thats why you bought new, no need for you to mess with it!
Posted on Jan 25, 2009
How do I remove the oven door from my electrolux icon oven
Good Morning Friend,
I understand you are trying to remove the door on your Electrolux Icon oven, model# E30SO75ESS. Being, that this particular model is a microwave as well as an oven, I suggest contacting your local authorized technician. They have been trained on this particular model and will be able to assist the best. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux ICON Designer E30SO75ESS Oven
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
My KitchenAid Double Oven Model KEMC308SS0 has a door problem (I think). Both Doors swing down past the horizontal level. Doesnt look right and they both do not close all the way. Opened one iin the...
I have spent $$$ on new hinges for my KitchenAid double oven doors over the past few years, but they always fail after 6 months or so. Recently I decided on an elegantly simple solution. K&J Magnetics (kjmagnetics.com) carries a line of 1/8" thick, countersunk Neodymium magnets that are perfect. I purchased a pair of their # RE22CS-N magnets (3/4" dia X 1/8" thick), attached them to the upper corners of the door just outside the gasket area with some #8 flathead screws, and viola! They do a great job of closing the door while still allowing a proper gasket seal. Lighter or heavier doors might require a different magnet, but K&J offers types with varying pull-in forces, so you should find one to match.
Sign up for our Monthly Newsletter kjmagnetics.com
Magnetics Incredibly strong...
Dec 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Resealing Inner Oven Glass
I guess you worked this out already as posted a while ago....but for others like me I thought adding a solution might help..........Open the door fully and on the hinges there is a clasp, flick that back on itself on both hinges. Close the door carefully and it will stop half way....now lift the door off the hinges. Lay the front of the door on the floor and there are 4 screws on the bottom of the door...unscrew the middle 2 (the outter 2 attach the hinges). then lift off the back of the door....you now have the access you need!
Now i have done this I need to get the sealant....is there a shop you can get this from B
Jul 16, 2009 | Electrolux Ovens
How do I remove the oven door to fix the inner glass that has come apart
Hi, The picture I looked up is very poor but, I believe you will need to open the door all the way. Look at the hinge and see if there is a small hole that you can insert a small nail into so that the door will not close all the way. Once you get this done, try closing the door and lift up at the same time. This should release the hinge inside the wall and allow it to pull off. Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Glass
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Feb 27, 2008 | Electrolux ICON 30 in. Double Wall Oven
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Ovens Logo
88 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
