Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My car stop responding
I had this product installed for about 2years and it was working perfectly until today when I try to lock or unlock the car the remote beeps but not the car like it used to please help
  • 139 Answers
Likely causes is the Viper's fuse has blown, the installation is faulty or the unit has failed. Without testing the system, it is not possible to determine the exact cause of the problem.
Posted on Jan 17, 2013
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Posted on Feb 28, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
SOURCE: My Viper 791xv remote isn't receiving the page
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
Posted on Jan 19, 2010
iadame
  • 676 Answers
SOURCE: My Viper 5701 has been
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
Posted on Jul 27, 2010
SOURCE: SKODA FABIA REMOTE KEY PROBLEM
my skoda remote does not function, i have change the remote battry , yet the same. how do i go about it.
Posted on Sep 09, 2010
Remote locking not working
sounds like remote is faulty you can try to reprogramme by turning ignition on/off 5 times until beep is heard then press any button on remote if lock button does not respond when pressed during this procedure it is FAULTY. you can try pulling apart and cleaning touch pads/switches
Jul 26, 2014 | Jaguar X-Type Cars & Trucks
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Bosch HME97 stopped working
Did you check the original fuse for continuity? Do so with an ohm meter if not. Does the display light up? If you take off the cover & look at the control board do you see anything burnt or, smell burn? If so, it will cost about as much for a control panel as it would for a new microwave.
Nov 15, 2013 | Bosch HME9760 Microwave Oven
"invalid IMEI", SIM not detected
Invalid Sim means get the Unlock code from service provider and Unlock it.....it locked to Network.
Aug 26, 2011 | Cell Phones
Codealarm keyfob on 2005 Mustang not locking/unlocking doors.
Try this http://m.wikihow.com/Reset-a-Factory-Car-Alarm g
Nov 20, 2009 | Code-Alarm Code Alarm Transponder
My Lexus LS400 was running perfect - no issues whatsoever. Today it won't start. Have tried jumping it but no luck. It acts like it is about to start but won't.
sounds like an engine immobilizer problem. close all doors,hood & trunk completely. lock and unlock the car three times with remote, then put key in door lock and lock & unlock three times.
did you accidently try to start with wrong key?
Oct 20, 2009 | 2005 Lexus LS400
2003 Escalade Keyless Remote not responding
You need to take it an have scan tool method done .
Mar 29, 2017 | 2003 Cadillac Escalade
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Program remote control for mazda mpv 2002
Courtesy of: forums.mazdaworld.org
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done
Dec 06, 2008 | 2000 Mazda MPV
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
82 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Tre Elkins
Shehu Pro
Shehu Pro
Joseph Gallucci
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
