Question about Epson Stylus RX500 All-In-One InkJet Printer
Can't print from shared printer
Using a client laptop, I can't print to the Epson RX595 installed on the host pc, which works just fine. Drivers installed on both machines, sharing selected on both machines, client pc will see and open the monitoring window showing status... then a communication error window will pop up. have reinstalled the drivers three times, and used every port available on the laptop. physical printer will not print, nor will the status window light up.
    Master:
  • 461 Answers
Did you connect the printer directly to the laptop to install the drivers? If so, you need to change the port to the network location to //hostcomputer/printer. You should also have the same user name and password set on both machines and have the user rights assigned to the printer sharing.
Posted on Jan 25, 2009
I have 20 nos of L300 device,each client has its own printer.The problem is that when I connect two printers of same model say hp laser jet 2014 on two different clients ,the printer does not work it shows...
The way the NComputing solution works, all the users are sharing the same host. So when you connect two printers, it's as if two printers are connected to that one host PC. When suing the USB port on the L300 you may have issues every time the device disconnects (like when a user logs off from their session) because the printer and it's respective port may have to be re-enumerated by the host. If possible, it might be better to do network printers. Also, when installing the printers, especially if you have the same make and model, make sure to LABEL them with unique names, i.e. Printer1, Printer2, etc. Otherwise, the host may have difficulty, more so the user, knowing which printer is 'theirs'.
Jan 25, 2011 | NComputing L300 Terminal Computer PC...
Epson rx595, installed compatible ink cartridges some time ago and it worked fine, now the yellow and the light magenta given error (cannot recognise ink cartridges,) put original epson that are empty back...
Swith machine off
clean pins in cartridge holder with (lightly) damped lint free cloth
Now try with compatibles
By the way, never mix originals with compatibles.
Good luck and don't forget to vote for more sharing.. thank you
Nov 22, 2010 | Epson RX595 Photo All-In-One Printer
Our HP desktop and Dell laptop are both connected to a AT&T 2 wire router/modem. The desktop is connected to an Epson non-wireless printer. How can we print wireless from the laptop? The laptop is...
You have to install the relevant drivers FIRST (Just install without printer thats fine) on the host & clients and then make sure you "Share" the printer on the Host setup. (The one where the printer is attached). Then on the clients you install a "Networked" printer and "Find" it on the network. Now ALL the PC's need to be in same"Workgroup" and have "Sharing" enabled on each machine, they all must have a name & password too..
Jan 30, 2010 | Epson Stylus CX9400Fax InkJet Photo...
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
Toshiba e studio166 shared printing problem
try adding printer and browsing network for printer, it should see the host and printer and add using correct network path, if you don't see host computer "print server" then you aren't on correct network path
Jun 24, 2009 | Toshiba e-STUDIO166 Printer
New Epson TX101 cannot print from network
'why i cannot cannot connect printer my network have some alitle bit computer that cannot connect and other can. I already check Computer Name, IP and WORKGROUP. but when i ping to computer that has printer it work. How should i do about this or this printer share only alittle.
May 13, 2009 | Epson Computers & Internet
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Client Printing + Word/Excel access times
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
369
Aug 06, 2008 | Microsoft Small Business Server 2003...
Epson Stylus RX500 All-In-One InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
