Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirlpool cabrio SN cy2870723--MOD# WTW6500WWl worked fine this morning but now its dead.I press the power button and nothing happens like it has no power but i checked the outlet with a lamp and i
We used it for about 3 hours sunday and when it was reloaded a little while later,the power button had no response so i unpluged it for 20 minutes and tried again but nothing.
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
s_4u_11
  • 535 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
Posted on Sep 16, 2008
SOURCE: Whirlpool Duet won't start
I had a similar problem on my Whirpool Duet Washer model GHW9150PW0. I found the solution here (Scott says his wire was cut, but in my case one wire of the control ribbon cable was frayed because it had fallen out of its holder and onto the tub assembly, part of which is so coarse that it ate through the insulation and wire by friction during the spin cycle). A quick splice of the wire to close the circuit and some tape to keep the cable from falling out of its holder and away from the vibrating, coarse tub assembly did the trick.
- George
Posted on Nov 01, 2008
  • 240 Answers
SOURCE: Whirlpool HE WFW9200SQ00 is Dead
control unit dead, replace main control and possibly user interface. Sorry this is very common failure on whirlpool.
Posted on Apr 26, 2009
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
Start button wont work
did you feel the clicking sound when button is press ? if no clicking sound , then it's the switch broken/wire loosen, if you cann't feel the clicking, then the plastic behind the button broken
Apr 21, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
My whirlpool cabrio SN cy2870723--MOD# WTW6500WWl worked fine this morning but now its dead.I press the power button and nothing happens like it has no power but i checked the outlet with a lamp and i know...
If there is no power to the panel check the power line. If there is power then check for fuse failure and if the fuse blows then it is due to shorting within the board. If however there is power to the board and the processor and there is no output to the functions then it is fault on the board, can be related to damage to the memory or processor IC.
Jan 16, 2013 | Washing Machines
Whirlpool Cabrio washing machine button does not work.
Possible that the main controller unit is faulty. You need to confirm the voltage on the controller unit and the connectors to the panel.
If there is no support from the controller then it can be faulty.
This requires testing the board for the processor and the set voltages for the board to function which must be measured..
Jun 05, 2012 | Whirlpool Washing Machines
The cycle doesn't start, when the start button is pushed nothing happens and the machine goes dead.
This could be one of a couple of differnt things,one is the switch is bad, 2 a wire is broken - 3 the timer is bad or you have a dead short which should if properly grounded will throw the breaker or fuse
Aug 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool dryer mod#len2000k01 press tha start nothing happens
First thing Is the circuit breaker, then the door switch.
Apr 07, 2009 | Whirlpool Dryers
F1 error on Cabrio washer
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
➔ If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
my check with part supplier is W10189966
Mar 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
