Question about PfaFF Tiptronic 2030
Pfaff 1171 - inserting new sewing needle
Having trouble inserting new needle -- I loosen knob and remove old needle but cannot get new needle up high enough to be able to tighten it in
  • Anonymous Mar 15, 2014
    install a new needle in a Pfaff 209
  • 66 Answers
Hello make sure that the needle is a front or side loading in the needle bar. the easiest way is to tell take the the needle with the flat side turn to the right or the left and see if it sides in either way hope this helps
Posted on Jan 24, 2009
Blanket stitch on Pfaff 1171
You need to check your owner's manual. Most machines of similar age do not have the blanket stitch.
Looking at Pfaff 1229 sewing discussion topic PatternReview com
(see comment)
Pfaff 1171 Tiptronic Sewing Machine
Aug 09, 2017 | PfaFF Sewing Machines
When winding the bobbin the needle continues to move.Whats wrong, I have done as is instructed...
loosen the knob in the center of the wheel you turn to move the needle manually this dissingages the needle drive
Nov 21, 2014 | PfaFF Creative 7570
HOW DO I CHANGE THE SEWING NEEDLE
There may be a tiny knob or screw that holds the needle in place. Loosen that and pull the needle out noting which direction the flat side of the needle shaft is facing. Choose the appropriate new needle for your project's fabric and insert the needle with the flat edge of the shaft going the same direction as the one you removed. Tighten the knob/screw and you are good to go. If you get interrupted or forget to note how the old needle came out, you should be able to look up into the needle holder to see where the flat edge goes.
Jul 14, 2014 | Sewing Machines
The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Oct 12, 2012 | PfaFF Sewing Machines
The thread keeps on snapping when i sew straight stitch?
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
try adjusting the top thread tension-to see if the tension is too tight
rethread the machine--top & bobbin just in case the thread is caught some where
check to make sure there aren't any burrs on the needle plate
Jun 05, 2012 | PfaFF Sewing Machines
When I set the machine up for free motion sewing the bobbin thread snarls
try changing the needle- Correct needle insertion is mandatory for proper use of your sewing machine.
check to make sure the bobbin is wound correctly & inserted into the bobbin corectly
clean under the needle plate area & in the bobbin area for lint or loose threads
if these suggestion don't help then it would be a good idea to
take the machine in for a check up
Jun 02, 2012 | PfaFF Sewing Machines
I have a BROTHER DISNEY pe770 EMBROIDERY MACHINE, THE THREAD IS BREAKING
Upper thread breaks--needle may be in backwards--
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Mar 24, 2012 | Brother PE770 Computerized Sewing Machine
The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
sewman7
Dec 29, 2008 | Necchi 3537 Mechanical Sewing Machine
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
225 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
