Question about iLive ITP582B Sound Bar with Play and Charge Dock for iPhone/iPodBlack
I have connected ilive ITP582 soundbar for better quality and clarity to LG 60PA6500 as manuals suggest. Using Optical in & out. No RCA audio out jacks on TV! Sound on Soundbar will only broa
TV - LG60PA6500
  • Larren Jan 22, 2013
    Connection from TV to ilive ITP soundbar via Optical cord alows only 30 - 40 % volumn? Help!
3 Suggested Answers
SOURCE: ilive 37
Turn off the sleep mode. For some reasons the geniuses ship it with a sleep setting already on. Hold the sleep button til it shows the time then press the sleep button several times until it displays 00. good luck!
Posted on Nov 25, 2012
  • 3247 Answers
SOURCE: how do i get a manuel for it202b soundbar
The manual can be downloaded from this site.
http://content.etilize.com/user-manual/1022923625.pdf
Follow instructions on top of page 7 using the Source button.
Posted on Jun 13, 2014
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
How do I connect ILive ITO82B Sound Bar to an LG TV?
This will depend on what inputs your sound bar has and what outputs your LG TV has, typically LG have Optical DIgital Audio (Sony TOSLINK), Headphone (Analog stereo), And HDMI reverse audio from HDMI 1 only. On some LG TV's you have to turn the external sound on, and on others it is auto detected, also make sure the TV speakers are off, or you can get weird phasing from 2 outputs (TV + Soundbar).
Jan 04, 2015 | LG Televison & Video
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
How do i connect a goodmans soundbar to an lg smart tv
The cheapest way of connecting your flat screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling..
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 09, 2014 | Televison & Video
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
You Can Use RCA Cables, Hdmi Cable Or Optical Cable Out From Your TV To The Sound Bar. Look At Your "Out" Choices From TV And MatchThe Same Style Of Connection On Your "IN" To The Sound Bar.
Jul 21, 2014 | iLive Audio Players & Recorders
How to connect a soundbar
All soundbars have a good old fashioned MINI, wich is the typical audio cable that runs with a VGA to a computer, the mini will link the soundbar with your tv.... you could go rca as well but a mini would be better.
Dec 27, 2013 | Televison & Video
How do i connect my HDTV to my YAMAHA HTR-5930 receiver? for example i am watching a movie from my usb port on my LG 42LE5300 or i am playing on my xbox, how do i get that sound to come out of the...
The simplest for the movie would be to connect the Optical digital audio out of the TV (above the VGA port) to the Optical Audio In on the receiver. You will need to get this cable from any store that sells TOSLink cables. The manual for the TV is available here: http://www.lg.com/uk/tv-audio-video/televisions/LG-led-tv-42LE5300.jsp . The manual for the receiver is available at the Yamaha support page if you are a registered Yamaha customer: http://download.yamaha.com/search/product/?category_id1=16445&&category_id2=16446&product_id=1060939 .
For the XBox, I'd suggest the same connection if you are using HDMI out on the XBox. If you are using component or composite video, route the audio cables to the receiver's RCA audio in.
I hope this helps.
Feb 22, 2011 | Yamaha HTR-5930 Receiver
iLive ITP582B Sound Bar with Play and Charge Dock for iPhone/iPodBlack Logo
60 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
