Question about BenQ MP622c Projector
BenQMP622c Projector wont pick up the PC as a source, always used to, we have 2 identical projectors in the office and have swapped over to the cables and PC of the other one that does work and the faulty one still wont pick up the signal there. Any advice would be greatly appreciated
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: dvi input problems
Hi 1ivans
I would suggest that you should firstly try another DVI cable.
If this doesn't work , then the comms board will most probably need replacement.
Posted on Apr 29, 2008
dhiman
  • 115 Answers
SOURCE: out of range
go to menu, set the input select option to Auto. If doesn't work the set it to RGB/Computer, this will work.
Posted on Dec 13, 2008
  • 13 Answers
SOURCE: projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Posted on Jan 28, 2009
projdoc
  • 2237 Answers
SOURCE: I have a DLP Benq projector (not sure the model
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
Posted on Sep 09, 2009
It say no source found
Hello Abugah,
For "no source found" errors, we recommend starting with the input device and the wires (assuming you have selected the correct input on the projector). Swap wires and sources until you figure out if the problem is with the projector or not.
If you are using a computer, make sure that it is on the right settings. On laptops there is usually a button you can press to cycle through display options (normally a function key + another).
If you figure out that it is, in fact, a problem with the projector we recommend going to a professional to fix the problem. If you are in the United States we can fix the projector. Projector AV Systems Repair Services
Before you send in the projector to anyone, contact Optoma to see if it is still under warranty.
Hope this helps!
Jun 30, 2014 | Optoma EX615 DLP Projector
Projector driver
the projector is flaw
something wrong with the mother board of the projector
something wrong with the interface board (video board)
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 10, 2014 | Vivitek Office Equipment & Supplies
Where is the projector connection on vaio fit
Insert one end of the VGA cable into your Sony Vaio. This is located on the left side of your computer.
Turn off the Infocus projector before connecting the opposite end of the VGA cable into the projector. The VGA input slot is located in the back of the projector.
Turn on the projector and allow time for it warm up.
Change the video output source on your computer to display through the projector. Press the "Windows" button and then "LCD/CRT" button on your Vaio keyboard to change the display source. On a Sony Vaio, the "LCD/CRT" button is usually "F7."
5
Focus the projector to most effectively display content from your computer. You can manually focus the projector or press the "Auto focus" button on the top of the projector.
Oct 02, 2013 | Sony Computers & Internet
My Infocus Screenplay 7210 projector will not detect any input source. It continues to say searching... Any advice?
reset the settings to factory default. then select auto source. swap out the cables, and make sure the resolution matches.
Jan 01, 2010 | InFocus ScreenPlay 7210 Multimedia...
Not picking up laptop as a source
the resolution may be different. the max resolution on the x350 is 1280x1024. if your laptop is any higher, you'll have to drop it. also make sure the cable is good.
Dec 28, 2009 | InFocus Proxima UltraLight X350 Multimedia...
When plugged into the laptop it continues to say searching and never connects
first reset the settings to factory default. then make sure that the source resolution is 1024x768. select auto search source. swap cables. if still nothing, you need to flash the projector with the latest firmware (check the infocus website).
Nov 05, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
When i connect my pc laptop to my digital projector (Epson) I always have problems with the pc picking up the projector. when i hook up my apple computer, the projector automatically picks it up. What am...
hi, you know that some pc can not connect to projector automatically so you need to press the functional key on your keyboard which is F4 or you will see an external monitor design on the functional key press it
Aug 09, 2008 | Computers & Internet
MITSUBISHI HC 100 PROJECTOR
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Jan 03, 2008 | Mitsubishi HC100U Multimedia Projector
BenQ MP622c Projector Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
