Question about Kenmore Dryers
I bought a used kenmore he dryer 417.94082500 should you see the flame in the back of the dryer drum? I opened the front and cleaned out the lint, there was a lot. Still shows flame even those the burner tube looks sealed going into the back of the dryer. Seems weird to me
    Sergeant:
    Champion:
  • 249 Answers
NO!!! you should not see a flame in the drum at all
Posted on Jan 17, 2013
  • 1 more comment
  • Beth Jan 18, 2013
    Let me clarify its not in the drum but behind it, you can see it though through the holes in the drum. Do you think the burner ends adjustment?
  • Charlie Lapinski Jan 18, 2013
    No there is a little hole on the bottom of the dryer is the only place to see a flame
    no where else to see the flume
catriver
  • 878 Answers
SOURCE: kenmore gas dryer
kuki, on a gas dryer, if the thermal fuse is blown, it will rotate but will not heat. If your dryer front has a lower panel, the fuse will be in front behind the blower housing. If not, it will be in back just like this pic. Ohm it out or jump it out temp to see if that is the problem. Post back, Catriver
Posted on Aug 31, 2007
Illeagle
  • 525 Answers
SOURCE: Kenmore series 80 gas dryer not heating
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 57 Answers
SOURCE: Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Posted on Jun 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
LG DLGX2502W gas dryer: inside the drum on the back wall where there is a grid w/holes, that had been burnt. I cleaned all the lint vents. The sensiflow shows no bars. dryer works. is it safe?
The gas burners are about 18" from that grid. The orange u see is the burner flame. The grid looks burned because of the heat from the flame. Try taking a shop vacuum to the grid and see if you can suck any lint from the burner chamber. If you get a lot, then it might be worth taking the dryer front off and cleaning it out. I doubt you have any safety worries. It is surprising how much lint gets inside of a dryer.
Jan 08, 2017 | LG DLGX2502W Front Load Gas SteamDryer,...
Kenmore gas dryer will not start after drying a couple of loads, but will restart after letting it sit for about an hour.
sounds like the motor is overheating and probably needs to be changed out.when was the last time you cleaned out the dryer and how old is it?the dryer should be taken apart and cleaned out once a year if it's gas and once every two years if it's electric.there's an open flame in a gas dryer and i've seen the lint catch fire in some of them.you should clean out the outside vent,if the vent line is a long run from the back of the dryer to the outside vent i use a leaf blower to blow out the line,clean out the duct that the lint filter slides into and with a shop vac i blow out the motor and vac out the cabinet where the motor is and blow out the gas tube,the lint builds up on the dryer motor,overheats it and all the oil in the motor dries up,you can see it on the back of the drum and around the motor,you'll see lint stuck onto the back of the drum stuck in the oil and like a yellow stain on the frame and wall where the motor is and the motor starts overheating and cuts out when it gets hot,when it cools it will start again but one of these times it wont start at all.sometime you'll hear a loud buzz when you try to start it.the motor is easy to change,you need to decide if you want to put money into the dryer or change it out,good luck
Aug 14, 2010 | Kenmore 63942 Dryer
I need to figure out how to get the front panel ff of my daughter's kenmore dryer Mod #96093800 to clean the lint from inside. Also the dyer heats up but doesn't get hot. any suggestions
First you have to remove the back and then top of the dryer, then you will have to remove the drum. After the drum is removed you may see screws along both sides on the inner corners of the front. (You may not have to remove the front once drum is out.) Remove these and the front should come off. There is usually lint jammed in the front tube if this dryer has a lint trap under the door, thus causing the heat not to circulate through the dryer.
Feb 21, 2010 | Kenmore Dryers
Hello, i'va a kenmore gas drier model 75818,the problem is that it does not heat up at all, have checked the ignitor and momentarely glows but after loud clicking sound it turns off,any ideas?,thanks,ray.
next time send the full model number,starts with 110. or similar,i would change out the gas coils located on top of gas valve, do one at a time and look for a metal spacer that needs to stay on post,sometime it slides off when you remove the coil,only on one of the coils,also if you haven't cleaned out the dryer it would be a good idea to do so, unplug dryer,if lint filter is on top remove the filter and the two screws in front of filter,remove the vent line if it's a long run blow it out with a leaf blower or shop vac but leaf blower works better,take off back wall and take out the four screws that hold the duct in that the filter slides into,clean out the duct,put it back together except for the two screws on top,now pop the top and remove the front panel and vac out the inside,if you have a shop vac blow out the dryer motor and all,if filter is inside remove the bottom panel take out the lint filter and remove the duct the filter slides into and clean it out,if you have a shop vac blow the lint from the back to the front so you don't have to pull the drum,blow out the vent line,you should do this once a year you have an open flame in there and you don't need a fire,your dryer will run better and last longer
Jan 31, 2010 | Kenmore 73932 Gas Dryer
Kenmore 110.72942100 gas dryer. slow to dry. heats a couple of seconds then off a minute or 2 then heats a couple seconds again etc. you can hear the gas valve go off & on. I'm checking this with the...
check outside to see if the air is blowing out with force,if the vent line is blocked with lint,also take off the bottom panel,remove the lint filter and take off the metal duct that the filter slides into,clean that out and vac out the inside of the dryer,if you have a shop vac the other side of it blows,blow off the motor and blow all the lint from the back to the front so you won't have to pull the drum to clean it,you should do this at least once a year more so with gas because you have an open flame in there and you don't want a fire,if the vent line is a long run i use a leaf blower to blow out all the lint out of the line,this is a common problem,next you'll start popping the thermal fuse or high limit thermostat
Jan 23, 2010 | Kenmore 74602 Gas Dryer
Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Dec 18, 2009 | Kenmore Dryers
I have a problem with my dryer, it is leaking water from it, was wondering where it might be coming from, any suggestions? I just dried a load of clothes and notice some water leaking from under the dryer....
all the dryer does is move air,if the steam can't move to the outside from a blockage of some sort your gonna find water droplets building up on and around the dryer,you need to clean out the dryer and this should be done every year so you don't have a fire also more so if it's gas with an open flame in the dryer,if you have a long vent line run from the wall to the outside use a leaf blower to clean out the line,first run the dryer and check outside to see if the flapper is blowing fully open,if there is a cage on the hood,throw it away,all it does is collect lint,if you want to keep it go out and clean it every month,if it's low to the ground this is used so no animals can crawl into the line,now unplug the dryer,take off the front panel and vac out the inside,then clean the duct that the lint filter slides into,ge drums ride on a rear bearing and the heater is on the back wall behind the drum,if you look inside you'll see holes in the back wall of drum,if you have a shop vac put it on blow and blow out the holes in the back of drum,alot of lint collects in there,hope this helps,you definetly have a block somewhere and the is is being restricted
Dec 17, 2009 | GE Dryers
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore elite HE4
THE AIR FLOW THROUGH THE DRYER BEGINS UP THROUGH THE HEATER AND INTO THE DRUM THROUGH THE HOLES INSIDE THE DRUM TO THE LEFT IN THE REAR.
THESE HOLES ARE METALIC IN COLOR AND MAY SHOW SIGNS OF DISCOLORATION DUE TO THE HEAT OF THE HEATER ASSEBLY. FROM THERE, THE AIR WILL FLOW ACROSS THE CLOTHES AND THROUGH THE LINT FILTER.
IF YOUR LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THE HOLES WILL BE IN THE BACK WALL OF THE DRUM ON THE RIGHT. IF YOUR FILTER IS LOCATED IN THE FRONT OF THE DRUM, THE HOLES WILL BE JUST BELOW IT.
USUALLY, LINT WILL COLLECT DOWN INSIDE THE SPACE WHERE YOU INSERT THE FILTER ON A FRONT LOCATION.
PULL THE FILTER OUT AND LOOK DOWN INSIDE. USE A CENTER CARDBOARD FROM GIFT WRAP TO CLEAN OUT THIS AREA. FLATTEN OUT THE CARDBOARD ROLL AND PUT IT DOWN IN THE SPACE ATTACHING THE OTHER END TO A VACUUM CLEANER HOSE.
ALSO, DISCONNECT THE DUCT WORK FROM THE REAR OF THE DRYER AND CLEAN OUT THE DRYER DUCT AND THE HOUSE HOLD EXHAUST DUCTING. WHEN REATTACHING THE FLEX DUCT TO THE BACK OF THE DRYER, MAKE SURE THERE ISN'T ANY EXCESS FLEX DUCT SNAKING BEHIND THE DRYER. CUT IT TO THE LENGTH NEEDED. MAKE SURE IT ISN'T FLATTENED BETWEEN THE DRYER AND THE WALL WHEN YOU MOVE THE DRYER BACK INTO PLACE.
Apr 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
