Question about Dell OptiPlex 760 MT Desktop Computer
How do I fix "Optiplex 760 failed at checkpoint [WRIT]" ?
I just got this computer. I was told that it was in perfect condition with just a few cosmetic wears and tears. That was not the case. The warranty is expired and I can't afford to renew it. I recieved the computer and booted it up. Not 2 hours into using it, it crashed. Just completely shut down. And would not reboot. I left it alone for a half hour and came back to see if it was working. It turned on but said this at the boot screen. "Previous attempts at booting this system have failed at checkpoint [WRIT]." Any ideas? Please help.
  • Dell Master
  • 1,147 Answers
This computer has known issues with the USB hubs which will throw this code. If you used a USB hub for a monitor or such it may have crashed the driver. Have you tried booting without any USB devices connected? If not please try.
Posted on Jan 18, 2013
5 Suggested Answers
  • 3940 Answers
SOURCE: Dell 8400. previous attempts at booting this
It is a Hardware error, and my be associated with the following components.
  1. Memory. Try Memory modules individually, see if you can get the system to boot normally with one or more modules, if you ID a defective one, replace it.
  2. Motherboard. It is possible, that if all combinations of the memory produce change that a failure has occurred in the motherboard. A swollen capacitor is a likely failure.
  3. The hard drive has a cache module, it is possible this memory is defective.
  4. The Processor (Least likely as they almost never fail.)
Posted on Dec 17, 2009
SOURCE: when booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on Jun 02, 2012
  • 222 Answers
SOURCE: "Previous attempts at booting this system have
you can see a logo screen at start computer?
if not the graphic chip are bad if you hear the fans to fast. you can try heat it using a heat gun .
you need to cover all using a aluminium sheet and discover the graphic chip. and heat it for 30 seconds. heat it making circular movement.
you can replace the mother board your self , and bought a used board and u will save a lot of money.
ebay have used and warranted parts for computers.
contact me if need more details , or if u have more info about your problem to figure it.
Posted on Dec 18, 2010
machineindep
  • 55 Answers
SOURCE: How do I fix this error "Previous attempts at booting this system have failed at checkpoint USB0?
go into bios and disable usb ports it should tell you while its booting up what key to press to get there like f1 or f2
Posted on Dec 08, 2012
Where does a dial up modem go in a Dell optiplex 760?
The dial-up modem would install inside the computer in a PCI slot. VERY easy to install but a couple considerations before doing so... There are different sizes depending on whether the OptiPlex is a mini-tower or small form factor case. Also - you would need drivers for the modem that are compatible with the operating system you have installed on the computer.
Apr 28, 2014 | Dell OptiPlex 760 MT Desktop Computer
Error checkpoint booting
Computer VGA (Vidoe Graphics Adapter) is stuck in low definition mode
Aug 20, 2013 | Dell OptiPlex GX270 PC Desktop
How it install audio devices for for omiplex 760
here is the page with the drivers for your OPTIPLEX 760. Select your operating system then select the one you want.
http://www.dell.com/support/drivers/uk/en/ukdhs1/Product/optiplex-760
Mar 01, 2013 | Dell Computers & Internet
When dell optiplex 760 pc turned on the power button keep in amber light. cpu fan was spinning but no video come out rom the screen. Aux power led in motherboard was lighted amber.
rmove the memory from the slot and clean it with a neat cloth and insert and switch on the computer if still not working remove the processor heat sink and clean it with a cloth apply some thin layer of heatsink solvent and fix them tightly also remove the cmos battery from the motherboard and switch on the computer then shutdown the computer and replace camos battery
Dec 30, 2010 | Dell OptiPlex 760 PC Desktop
Booting failed at checkpoint [WRIT}
May be a cpu problem. Make sure the fan is on the cpu and that it is running. If the fan is running you may need to change the thermal compound that is between the cpu and heat sink. If that doesn't work , the next step would be to try to use another cpu that you know is good and see if it fixes your problem.
Nov 01, 2010 | Dell Optiplex GX270
How to turn off beeps on anOptiplex 760? Thanks.
I've got a few options that will work for you here. They are outlined below.
1.When starting up the computer, start hitting F2 to enter the BIOS.
Look under "Integrated Devices" and you will see system speaker there, and can be turned off. 2.Open up the case to your Optiplex (Simply push down release tab and remove side cover). Locate the system speaker, and unplug it. 3.Go into device manager. Right Click "My Computer" and select Manage. Choose "Device Manager" from the left side. a. Click View >Show hidden Devices.
b. Expand "Non Plug and Play Devices"
c. Double click "Beep"
d. On the Driver Tab set the "startup" type to "Disabled"
e. Reboot. Let me know if this fixes your issue. Look forward to hearing from you soon.
Feb 25, 2010 | Dell OptiPlex 760 MT Desktop Computer
Alert! previous attempts at booting this system have failed at checkpoint [WRIT.] -- Optiplex GX270 Dell Computer
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
Jul 07, 2009 | Computers & Internet
Dell OptiPlex 760 MT Desktop Computer   Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
