Question about Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White
Can not remove agitator - Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White
  • frank ritz Jan 19, 2013
    the way to remove the agitator is first remove the cup on the top of the agit ator and then reach your arm insde the agitaor and remove the screw that is holding in place. Then lift the agitator out.
  • Fisher Paykel Master
  • 17,130 Answers
Please check on this link for tips: Agitator.
Posted on Jan 17, 2013
Removing kenmore agitator 417.94862302
You do not have agitator dogs in your machine, yours is made by Frigidaire the agitator can be removed by removing the top of the agitator and remove the bolt. It is screwed directly into the transmission shaft, You want to check the belt to see if it is stretch out , just normal from use.
Feb 06, 2014 | Kenmore 24032\24036 Top Load Washer
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Agitator not working properly...lower part works while the upper part just sits there not turning
you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
Dec 31, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
Nov 30, 2009 | Kenmore 24622 Top Load Washer
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Agitator not agitating to wash cloths.
remove top of agitator remove plastic cap inside agitator housing. remove 7/16 in. bolt. lift out agitator
Jun 20, 2009 | Washing Machines
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I am unable to remove the agitator from my Kelvinator K605 washin
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
he agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
read more about the agitator removal in the next comment.
Jan 30, 2009 | Washing Machines
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Shoestrings wrapped under agitator
You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
Nov 03, 2007 | GE WPRB9220D Top Load Washer
Fisher Paykel Fisher & Paykel Elba 3.7 cu ft Top-Load Washer - White Logo
67 people viewed this question
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Lawrence Oravetz
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
