Question about GE GSH25JFT
Freezer fan makes noise - GE GSH25JFT
    Problem Solver:
  • 11 Answers
Check to see if the fan blade is touching the frame and adjust. if its not touching anything but making noise change the fan
Posted on Jan 17, 2013
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
REFRIGERATOR FREEZER IS MAKING A NOISE
Noise inside the Freezer
If your freezer is making a squealing or a little chirping sound, your condenser or evaporator fan is the cause. Open up the freezer door, and the noise usually gets louder. The location of the fan depends on your model freezer. Usually, the fan is located on the rear wall of the freezer. The fan can lose lubrication or become rusty over time. You cannot repair the fan. You must purchase a new one.
Have a nice day : )
Sep 05, 2011 | Refrigerators
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refridgerator make a noise every 3 minutes
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 29, 2010 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Freezer makes intermittent fan noise
one time i ran into this problem and found out the lady was putting hot things in the freezer creating alot of moisture. check your door seal also make sure its sealing if it had gaps you can heat it up with a hairdryer to streach it out.
Mar 28, 2010 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
FAN IN THE FREEZER DEPT MAKING NOISE MAYBE FAN
if the fan is making noise it can also due to dust collected in the fan winks towards it end.or the other option is motor getting weak and needs replacement.
Feb 20, 2009 | Hotpoint HSS25GFP Side by Side...
GE ADORA DSS25KSRDSS FREEZER FAN NOISE
Unplug your unit and check the fan blade by manually rotating it with your finger, check if the blade is not touching the fan blade frame. Check if the screws are not loose, align the fan blade and re tight the fan blade screws.
Jan 08, 2008 | Refrigerators
GE GSH25JFT Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
