Question about Microsoft Xbox 360 Console
Halo3 Problems Every time I do the level ''The Covenant''It'son 12% then it goes back to zero.I had this problem for months and I really need help.
  • Jordan Anderson Jan 28, 2009
    No.
  • Aegis Kay
    Aegis Kay May 11, 2010
    Do you have an Xbox 360 core or arcade system or any of the full systems?
    Problem Solver:
  • 11 Answers
Is your disc scratched?
Check to see if any accessories are causing the problem loadTOCNode(2, 'whattotry'); Turn your console off, and then remove all the accessories that are attached, including the Xbox Hard Drive. Turn the console on to see whether the problem still occurs.
  • If the problem does not occur when the Xbox Hard Drive is disconnected, try clearing the Xbox 360 Hard Drive cache. To clear the Xbox 360 Hard Drive cache, follow these steps:
    1. Re-attach the Xbox Hard Drive.
    2. Locate the System section of the Xbox 360 Dashboard.
    3. Select Memory, highlight Hard Drive, and then press Y to view the device options screen.
    4. On the Xbox 360 Controller, press the X button, press the X button again, press the left bumper, press the right bumper, press the X button, and then press the X button again.
    5. You will be prompted to confirm system maintenance. Select Yes by pressing A.
Posted on Jan 25, 2009
Ibanez troubleshoot
Strings are on the bridge backwards!
Jun 06, 2017 | Music
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
Last time used 18 months ago, ran good, no problems. Tried to start it and it won't go...So I checked oil level..(good) removed the fuel bowl replaced old fuel with new fuel all looks well and cle
heat the spark plug for a few minutes then put back in the engine. sometimes works when you not used engine in a long time. it will take a good few goes to get the old fuel out of the carb, the heat helps burn old fuel.
Jul 09, 2017 | Motorcycles
I purchased a GE coffee grinder about 6 months back. Used it about 5 times. The on light comes on but the grinder doesn't work? Need help!
Check the connection at the relay.
Check that around 12-24 volts is present at the relay (the wire goes from control board to relay).
If its present then check 120-140v present at the other terminal of relay.
If both is true then unplugg the grinder from main board.Isolate the motor from all the wires and check the coil resistance.(zero resistance conclude that motor is bad).
Thanks
please rate my work
Sep 11, 2011 | Coffee Makers & Espresso Machines
Need instructions for 96845 Halo Wars Covenant Brute Chopper
They're on this page!
http://www.megabrands.com/en/customerservice/instructions.php?brandSelect=176&dir=customerservice&level=3&level2=3
Oct 10, 2010 | Mega Bloks 613 Blocks Lego Style Cat...
My sons 98 Mountaineer won't move in
It's a gearbox problem. You really can't repair this yourself. Only if you're a professional mechanic
Dec 01, 2009 | 1998 Mercury Mountaineer
Why my haLO FAILS TO LOAD CONTENT
look for a scratch on the disk. any at all can cause this to happen. sorry but you might need a new copy
Jul 04, 2009 | Microsoft Xbox 360 Console
Oil pressure is low in my 1996 jeep grand cherokee limited
first try changing the sending unit,if your not hearing any knocking when it drops too zero then you dont have any majior problems
Mar 15, 2009 | 1996 Jeep Grand Cherokee
Change time
This must be done at extension 10 or 11:
Press Feature and dial zero zero
Press the left intercom button twice
To set the time, press the pound (#) key and dial 103. Enter the correct time using a 24-hour clock (if it's afternoon, add 12 to the hour...i.e. 3pm is 1500)
To set the date, press the pound key and dial 101. Enter the correct date using the format MMDDYY (two digit month, two digit day, two digit year).
Press Feature and dial zero zero to save your changes.
Oct 30, 2007 | Avaya Eurostyle 18D Corded Phone
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
