Question about Dell OptiPlex Computers & Internet
Virtual Box Internet Issues
I have Windows XP Pro in the PC but I have virtual Box installed which has guest Vista I am unable to connect to the internet on Vista but I can connect to the internet on Ubuntu (Also on virtual box) and Debian (Also on virtual box) I am getting internet on my Host XP PRO though.
    Novelist:
  • 187 Answers
OK...so what is your question exactly? all that info and i cannot figure out what you need?
Posted on May 17, 2014
SOURCE: error
Hi, While installed the Virtual pc and open the same in the dell gx520 this error will appear -get a solution. Virtual pc is incompatible with PAE mode. This version of virtual pc cannot runwith PAE(physical address Extntion)mode enabled on the host.please disable this feature
Posted on Feb 22, 2008
  • 149 Answers
SOURCE: Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Posted on Dec 30, 2008
vkyhunk
  • 156 Answers
SOURCE: no drivers after re-install xp
Hey Hi,
My frenn u need not worry.. just copy and paste the link below and download the drivers and copy it on a USB PEN DRIVE and then install them on your desktop.... Install the drivers in the same order as i have mentioned below...
CHIPSET DRIVERS
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R41334&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=3268&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=27&fileid=48256
VIDEO DRIVERS
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R79733&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2441&devlib=0&typecnt=0&vercnt=5&catid=-1&impid=-1&formatcnt=1&libid=6&fileid=104486
NETWORK DRIVERS
1st OPTION
(IF YOUR SYSTEM HAS 3Com 3C905C-TXM Ethernet Adaptor then use the link below)
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R49958&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2730&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=58953
2nd OPTION
( IF YOUR SYSTEM Intel 10/100 LOM then use the link below)
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R56484&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2834&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=67420
AUDIO DRIVERS
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R71579&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=92933
IF U R CONFUSED IN WHICH NETWORK DRIVER DO DOWNLOAD AND INSTALL THEN JUST CONTACT DELL TECHNICAL SUPPORT AND ASK THEM WHICH NETWORK DRIVER TO INSTALL, EVEN IF YOUR SYSTEM IS OUT OF WARRANTY THEY CANT DENY YOU TO TELL YOU ABOUT YOUR SYSTEM SPECIFICATION..
kindly rate this solution if u think its helpful to u..
Posted on May 28, 2009
  • 226 Answers
SOURCE: Why does my monitor keep losing signal? I have to
just uninstall ie 8 and see if that will fix it
Posted on Jul 20, 2009
  • 5 Answers
SOURCE: Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Posted on Sep 30, 2009
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
Tip
Windows Virtual PC & Windows XP Mode Resources for Windows 7 These are some of...
Windows Virtual PC & Windows XP Mode Resources for Windows 7 These are some of the resources for IT Professionals for deploying Windows Virtual PC and Windows XP Mode in the corporate environment. This new desktop virtualization platform enhances the overall business productivity for the corporations by leveraging the Application Compatibility with the help of XP MODE delivering easier migration to the newer version of Windows operating environment. Installation instructions and Release Notes for Windows Virtual PC and Windows XP Mode Windows Virtual PC is the latest Microsoft virtualization technology. You can use it to run more than one operating system at the same time on one computer, and to run many productivity applications on a virtual Windows environment, with a single click, directly from a computer running Windows 7.
For more information about Windows Virtual PC, please visit the Windows Virtual PC website.
The Setup and Install instructions document describes how to install and setup Windows Virtual PC and Windows XP Mode. You should familiarize yourself with all of the information especially if you are upgrading from the Windows Virtual PC and Windows XP Mode Beta or Release Candidate builds.
The Release notes provide important information you should know prior to installing and using Windows Virtual PC, including known issues. You should familiarize yourself with all of the information prior to installing the software.
DOWNLOAD HERE
Deploying Windows XP Mode This document and files provides the guidance and scripts necessary to deploy Windows XP Mode in a corporate environment.
DOWNLOAD HERE
Windows XP Mode IT Pro Deployment Video This video highlights the many features of Windows Virtual PC and Windows XP mode and provides guidance on deploying in a corporate environment.
DOWNLOAD HERE
on Jan 10, 2010 | Computers & Internet
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
Is it possible to install Windows XP as a second OS on ASUS K61ICX3 Notebook. All my games need Windows XP. Thank you.
Probably. I would check out the Sun microsystems program "Virtual Box"
This is what I use. I have an older (maybe 6 years old) Toshiba laptop which runs Windows XP. I installed Virtual Box and use it to run Windows 7 as a guest system.
Go to this site to get it: http://www.virtualbox.org/
Jul 21, 2010 | ASUS K61ICX3 Notebook
My favourite programme - Print Artist 4 which has worked with all my computers up to and including XP will not work with Windows 7 - what can I do?
It means that this application is not compatible with Vista or Windows 7. If you have Windows 7 Pro or Ultimate, all you have to do is run the app in XP mode, which is really running an XP virtual machine inside of Windows 7. Just look in Windows help for instructions on how to do it. If you have Home Premium or less, they do not have XP mode. Instead you can download Virtual PC 2007 SP1 from the Microsoft web site for free, install it, then create a virtual machine that uses XP. You will have to have a licensed copy of XP to install on the virtual machine. Then install PrintArtist on the virtual machine and you are ready to go. You can use the virtual machine and Windows 7 on the host system simultaneously and can even exchange data between the two.
Feb 11, 2010 | Computers & Internet
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
HOW TO INSTALL XP IN VISTA OS OF LAPTOP HP PAVILIION
Hi there.
The only way you can install XP on a Vista machine is to install "virtual XP" onto Vista using Virtual PC 2007.
Here is a site that will take you through the procedure step-by-step and gives links to download Virtual PC and install it onto the machine.
Please be aware that some drivers may not work whilst using XP when you have it installed.
http://lifehacker.com/software/windows/geek-to-live--run-windows-xp-inside-vista-with-virtual-pc-238071.php
Have fun, good luck and thanks for using FixYa!!
Mar 23, 2009 | HP Pavilion DV6700T Notebook
Usb ports are not working in Virtual Pc
Install Virtual Machine additons and u can share the folder between the host and guest pc.
Dec 28, 2008 | Microsoft Virtual PC 7 with Windows XP...
Upgrading an Acer Aspire 2008 model to run windows Xp in one partition and Vista in another
http://apcmag.com/how_to_dualboot_vista_with_xp__stepbystep_guide_with_screenshots.htm
You'll probably find this website most useful. This website was designed for users who want to dualboot that already have XP on their machine. There is a link to a how-to for users who already have Vista installed and want XP also. Good luck and I hope this helps.
Apr 13, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
Alun Cox
