Question about Kenmore 22422 Top Load Washer
My washer wont spin
What and how can i fix it
  • Mark Egan May 11, 2010
    Does the motor run?
    If so, does the agitator agitate?
    Please reply the complete model number for further help.
110.22722991
Posted on Jan 25, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
LG washer will not start
How to Fix an LG Front load washer machine that wont spin ...
? 5:32
www.youtube.com/watch?v=J11Thy0vW0Y
Nov 30, 2012 - Uploaded by Zack Nelson Diagnosing an LG frontload washer machine that wont spin. Also tells you how to get into the diagnostics ..
Aug 06, 2015 | LG Washing Machines
HOW fix myadmiral washer model AED4475tq0
check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
Jan 14, 2015 | Admiral Washing Machines
Kenmore washer model 11022722100 wont spin out wet clothes
the PCB has a problem and only a certified tech should try repairs
Sep 13, 2017 | Washing Machines
Washer will not spin
The brake mechnism is not releasing when the motor spins the bottom pully counterclockwise. The pump might still spin and drain the tub, but the can wont spin. A transmision repair lit can be an easy fix for about $30. Kit should include a new wheel pully, and a bearing and washer kit and also an insert that goes inside the gear pulley. See my other solutions to fix this issue.
Sep 22, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer wont spin
The brake cam driver has an ear on it. They tend to break off and this won't release the brake. If that is good then you might need to check the clutch.5ff0d60.jpg Look for a thin liner or oil on the clutch. If that is the case you need to change the tranny cover seal.1c95618.jpg If that is good then inspect the main drive gear and pinion.1edfdd4.jpg These gears get smooth and won't grab.3ce3530.jpg If that is good then remove the main drive gear and look for a smashed down spin pawl. If it is smashed down it won't catch a boss under the main drive gear and spin. Training Manual
Jun 15, 2010 | Kenmore 24032\24036 Top Load Washer
Wont engage to spin mode
most likely a broken washer tub drive belt or coupler.
Oct 30, 2009 | Roper RAS6233KQ Top Load Washer
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
