Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE force defrost
Need to force defrost
  • GE Master
  • 4,654 Answers
Instructions are found here=> GE ARTICA PROFILE TECHNICAL INFORMATION Be careful while jumping terminal J11 to J9 because you are working with live voltage! The service manual can be found HERE I am here to answer any questions, Thanks Sea Breeze
Posted on Jan 18, 2013
GE REFRIGERATOR MODL # PDS22SCRRSS WONT DEFROST THERMOSTAT ALREADY REPLACED HEATER OK HOW DO YOU FORCE A DEFROST?
Bypass the defrost timer by jumping it and applying current directly to the defrost heater element.
Jan 16, 2017 | GE Refrigerators
Force a defrost cycle in a ge gsfs6kk
Unplug it for more than 2 minutes defrost is the default turn up the temps prior to unplugging
Feb 14, 2015 | GE Refrigerators
Freezer works fine, but refrigerator above isn't cool enough?
Sounds like a defrost problem. Most likely the defrost heater or defrost thermostat. I can show you how to force defrost and send the manual that covers how to on those models. I will send in a few moments, Sea Breeze
Apr 10, 2010 | GE GBS22HBP Bottom Freezer Refrigerator
Back wall of freezer has lots of ice, evap fan not turning and the upper part of the whole fridge is warm..
The defrost system needs your attention. What I would do first is force defrost, check for amp draw of heater, and replace heater and terminator(defrost thermistat).
Feb 20, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
How do i advance the defrost timer
You don't have a defrost timer, you have a mother board probably on the back of the unit. It determines when to defrost based on the usuage of the unit.
you can force defrost with a jumper from J11 to J9, then monitor current. Assuming fridge is freezing , this should supply current to defrost coils. If not working, you have a bad heater or defrost thermostat. If this works, you have a bad mother boar
Sep 04, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
How do you test the defrost heater to see if it is functioning? We had same issue several years ago and the defrost heater was the issue. Before we buy parts, is there a way to test to see if that is truly...
You can remove the wires from the heater and using a volt/ohm meter set for ohms,test the heater terminals. If it reads it is good. If it does not read it is bad.
Or,you can force the fridge into the defrost mode and wait for the heater to come on. Find the defrost timer and turn it to the defrost setting.
This being a GE refrigerator it is probably the heater and the defrost thermostat.
Aug 30, 2009 | GE Refrigerators
Ge mod.pde18lzpbww.defrost tray ice buildup every
Remove the rear panel inside the freezer . Defrost the drain tray whr=ere the drain hole is until water will flow down it . Hot water sometimes helps . Use a small hose inserted into the drain and blow out any debris . Get a Solid ALUMINUM wire about 9 inches long (14-16 guage) and put into the hole as far as possible without using force (bend the wire if necessary) and make a hook with the other end ahich you should hook onto the defrost heater . This ALUMINUM wire will keep the drain hole cleared of ice due to the transfer of heat from the glass defrost heater . Do not make the hook too tight for fear of breaking the glass covering on the heater .
Aug 16, 2009 | GE Refrigerators
How do I force a defrost on a ge sxs gss20iepcww It is not a touch pad control ref. It has 2 knobs
on all ge electronic models produced since 2000 the main power lead to the main board can be jumped to test either defrost or compressor operation.to do this unplug the unit and locate the 3 wire plug (usually blue in color) .unplug the harness from the board and create a jumper wire to by pass the board.the terminals on the board will be identified as line,compressor and heater.to put unit in defrost install jumper between line and htr or def .this will ck the defrost sys.once unit is plugged in with jumper in place the heater will come on.if the heater does not come on look for a defective heater or defrost t/stat.hope this helps.
Jun 03, 2009 | GE Refrigerators
GE refrigerator gsl25xgwss defrost problem
Either heater or Board is most likely bad. You can remove heater and test it with ohm meter for continuity
Oct 05, 2017 | GE GSL25XGWSS Stainless Steel Side by Side...
GE refrigerator not defrosting
To force this unit into a defrost mode, unplug the fridge and remove the cover from the main control broad and remove the main wire harness. (Three wires, Black, Blue and Brown I believe) Next take a a small 3in wire and bend it into a U shape to make a jumper.
Insert the jumper into the main wire harness to jump the to outer wires together. (Black to Brown) It should be pretty easy to slip it in through the back with the rest of the wires. (Don't worry this test will not cause any harm to your fridge)
Now reapply the power to the fridge and check the defrost heater. As long as the defrost thermostat is below 15 degrees then the heater should start working. If the heater doesn't work then there is a problem with either the defrost thermostat or the heater. GE uses a glass tube heater with a coiled wire inside. This wire has a habit of breaking after a few years.
As far as the thermistors go, all the do is tell the board to cool. They can make the unit cool all the time but the board should still defrost the evaporator every 6-36 hours. If the unit starts defrosting then you have a bad board.
Hope this helps and let me know if you need any clarification. Good Luck!
Nov 03, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
306 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
