Question about Fisher Paykel EcoSmart GWL15
Gentle Annie GW52-F The cold water is just dribbling in.
Am trying to remove the control panel without success. I have removed every screw in sight but although I can remove the entire top of the machine, I still cannot get into the Control Panel and am worried that I might break something if I force it. I suspect that the cold water solenoid might be stuffed. Can I swap out with the hot water one as we only do cold washes. My questions are: 1/ How do I get into the control panel 2/ Can I swap out the solenoids or just change over the hoses and run as hot wash only?
  • Fisher Expert
  • 554 Answers
Don't run hot wash only as the spin cycle will be reduced to a slower speed. Can you swap the wires and hoses to the solenoids only and try that.
Posted on Dec 15, 2013
How do i remove the top screw that holds the control panel
First you have to remove the trim from the top, there are two screws holding that and then a bit of gentle prying/wiggling. If you're having trouble with the unit randomly resetting, try torquing the exposed screws behind the control panel. The important one is probably the grounding point. It seems to have done the trick for me, three weeks and no SE- codes.
Jun 21, 2014 | Samsung SMH9187 Microwave Oven
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
1994 s 10 blazer pwr windows not working ......all 4
Checking for blown fuse is a common problem fix, but your master control on drivers door may have a loose conection, or may be faulty. Remove all surrounding screws for door control pad and with gentle prying should loosen pad without removing door panel.Press together all connectors. Windows should operate. if pad dose not come free door panel must be removed.
Apr 13, 2013 | 1999 Chevrolet Blazer
Hoover 700l Cold water is not fillingproperly. Only a verey small dribble comes into the machine. I have reversed the hot and cold hoses, making sure that the setting is on "hot". Problem...
Clogged screen in fill valve on cold side. Remove hose from cold side on valve. Pull screen out. Wash under hot water, and re-install.
Jan 23, 2011 | Washing Machines
Fisher & Paykel Gentle Annie washing screeching sound
remove drive belt.check 2 see if main drive pulley turns freely.check to see if motor turns freely. could b belt. what country r u in . parts hard 2 get in australia. please reply 4 more help. please turn off power b4 u work on it. do not want any accidents.good luck
Apr 04, 2010 | Washing Machines
I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Feb 17, 2010 | Washing Machines
Gentle Annie wont pump out water
could have a sock in pump vac and towel needed unplug empty water remove drain hose shop vac pump and both hoses turn on to see if pump motor runs
Feb 04, 2010 | Frigidaire Washing Machines
Hi.I have a Gentle Annie that starts and stops filling with water
It is most likely the lid switch. The switch sits in a plastic bracket which has a lever coming down behind the tank.
If the tank sways and hits that lever, it cuts off the cycle as a safety measure. When the switch is faulty or more often when the plastic bracket breaks, you get this symptom.
Let me know if you need more assistance.
Ash
Oct 22, 2009 | Fisher Washing Machines
Water fills very slowly. I've removed the hot and cold supply hose and found no clogs. Water flows well from the taps, but dribbles into the wash load.
Did you check the screen filter in the end of the hoses on the washer and the end that screws to the water supply.
Oct 14, 2009 | Washing Machines
Whirlpool washer model lsr8233eq1 Hot water flows into the tub terrific. Cold water is always just a dribble. Not the hoses or water pressure. How do I get inside to where the water connection/flow...
Hi gastang,
The problem is with your water valve. It needs to be replaced.
To access the washer follow these steps...
UNPLUG THE WASHER!
1.) Remove the 2 screws from either side of the control panel.
2.) Pull the control toward you a 1/4", then rotate it up and all the way over.
3.) Remove the white plastic wire connector to the top panel (it has 3 wires in it.).
4.) Remove the two clips on either side of the top panel. Do this with a screwdriver. Poke the screwdriver into the top panel to engage the clip, now rotate the screwdriver toward the rear panel.
5.) Lift the lid (for a hand hold) and rotate the entire cabinet forward to about a 45 degree angle then slide it toward you. Set it aside.
Here's a video that shows how it's done. But you'll notice that the screws on your control panel are in the front, the video has the screws in the back, but the rest is the same. Here's the video.
After you have access, you'll see the water valve on the right.
If this was helpful, would you take a moment and rate my solution? Thanks,
SG
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
