Question about Dishwashers
Bosch shu3032uc/u12 dishwasher
Need manual not draining
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher SHU3032UC/U12: Gets
Welcome to FixYa.
Based on you description of the timer not advancing you`re on the right track when you said "Thought it might be the timer (control unit), but now am wondering if it could be the heating element or thermostat"
I suspect the thermostat isn't satisfied when heating the water, hence it get`s hung up trying to heat in the part`s of the cycle it`s called for.
It very well could be caused by a faulty flow switch, NTC or heater as well but not very likely.
The SHU 30** series Bosch dishwashers with a rotary dial timer have very few if any, issues with the actual timer or element but they do with the thermostat within the door panel.
If it ( the thermostat ) is not satisfied the water may heat but not be indicated via the thermostat, hence timer will not advance.
Here`s what you can try. If you have any hesitation or reluctance to service this yourself please call in an authorized B/S/H/ appliance technician.
**Turn off the breaker at the service panel before attempting any service suggested **
  1. You will require a #20 torx screwdriver to remove the door panel by taking out the screws around the panel, except the ones along the top ( watch the edges they are very sharp )
  2. Once the panel is removed you should see the thermostat over by the detergent dispenser clipped to the inner door, remove it and test it. You`ll need a ohm meter/multi-meter plus a lighter or match to heat it up to see if it open`s & closes.
Example...
**NOTE** it can occur the thermostat can become loose and detach from the bracket which holds it in place, this too can manifest in the sysmptom of the timer not advancing.
Let me know how you make out and what you find.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
Testimonial: "Wow, loads of good inf to try to fix my dishwasher! I appreciate the very detailed answer to my question."
Daniel S
  • 4323 Answers
SOURCE: Our Bosch dishwasher won't rinse.
Hi
The issue is with the water inlet valve assembly that is bad and so the water won't enter the unit. When the water inlet valve goes bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 17, 2011
Kenmore HE 2 plus washer manual
Long drain Pump may just be clogged or need new pump\
L21 error long drain not draining fast enough
May 24, 2016 | Kenmore Washing Machines
Why do i get f5 code on my samgung dishwasher
The F5 code means that the machine is not draining.
Either there is something blocking the drain line or the drain pump is defective!
first check the filter then the drain line!
Jan 02, 2015 | Samsung Dishwashers
How to drain gas tank 08 vstar 1300
Hi, George for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
EASY Empty Motorcycle Gas Tank
How To Drain Motorcycle Gas Tank
Completely drain fuel injected motorcycle tank
Yamaha XVS1300A 2007 Service Manual
OEM parts for Yamaha
YAMAHA XVS1300A Owner Manual
Jan 28, 2012 | 2008 Yamaha V Star 1300 Tourer
How do I manually drain the water from the basin of my old, heap of a Whirlpool Model LSQ8543JQ0? It's out of here in two weeks, but in the meantime, I have no lid switch left on it, and it's full...
to manually drain it simply take the drain hose and hold it toa lower level athe the bottom of the tub(toward the bottom of the washer) and the water will drain right through the drain hose...depending on if ya have a floor drain to drop the drain hose into ya may need to raise and lower the drain hose several times intoa bucket...if ya have a floor drain put the drain hose in it and it will drain completly through that drain in the floor.
GENE
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
Where can I find an online trouble shooting guide or owners manual for my Kenmore dishwasher 36314489100? It will not drain.
Hi
You can download the manual from this link--
Kenmore dishwasher 36314489100 User Manual
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 20, 2011 | Kenmore Dishwashers
I have a Fisher & Paykel dish drawer model number DD603 and it is not draining. Any tricks?
Hi
Dishwasher not pumping issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please check the parts manual for your dishwasher, check the drain pump & drain filter's location from the link---
Fisher and Paykel Dishwasher DD603 Parts Manual
Please note that dishwashers don’t pump out the complete water such that heating element doesn’t overheat. Please post back for any further assistance.
Daniel
Aug 07, 2010 | Fisher and Paykel Dishwashers
Dishwashers Logo
155 people viewed this question
Top Dishwashers Experts
